Go to Post Please stand up and be proud of who you are and what you believe in! - MattK [more]
Unread 10-01-2008, 08:12
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Red face Gyro Heading always zero, yet operating?
Can I get some help in determining why the gyro heading is always ZERO but the gyro counts change when I swing the device? I have captured screen shots into powerpoint and will zip them, then attach to this message.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 10-01-2008, 13:21
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Gyro Heading always zero, yet operating?
I had to look up the printTextToGD function call from WPLib.
void PrintTextToGD(unsigned char ucRow, unsigned char ucCol, unsigned long ulColor, rom const char *szText, ...);
Usually when we have a problem like yours, it is a typecast problem.
Other things to check:
Is your color valid?
Is your gyro type set correctly? You have the 300 deg/sec gyro?
What affect does the wait(200) have on your program? I always prefer to wrap my print statements in a if block for what you are trying to do:
if (time%$200 == 0)
printTextToGD.....
That way the program can continue to process gyro data, although WPLib documentation implies that sensor data is still processed during the wait.
Unread 10-01-2008, 14:26
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
It sounds like the sensor is recording the change (derivative) and not the elapsed angle (integral).
If you want to get the elapsed angle, you can just add/subtract the difference every time through the loop to keep track of the absolute angle. You may have to do some simple calculations to make the sensor value you are getting back correspond directly with degrees rotated.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 16-01-2008, 10:54
marccenter's Avatar
Team Role: Coach
Hey guys, I finally got the gyro to work. It help's if you actually Start the thing.
Thread can be deleted, if desired by moderator. Thanks for CD help.
Marc Center
Floating point math zero flippo Programming 3 09-02-2007 09:00
Keeping a certain heading using a gyro DanDon Programming 12 08-03-2006 14:27
OI and analog: Zero value Astronouth7303 Programming 1 02-02-2004 16:00
Community Zero archiver 2001 1 24-06-2002 04:08
Zero Hour archiver 2000 4 23-06-2002 21:59
