Re: Disengaging a motor on a spring powered hurdler
We were thinking of using a gear with teeth missing to pull it back, although that would require a non-winchy device.
Why not mount a winch so it can spin freely, then use dog gears to engage/disengage it?
I like your idea about the shifters. Andymark makes planetary gearboxes that changes the output of a Fisher-Price motor into that of a CIM. Two FP's Into that, into a Gen2 with one of the speeds taken off should be plenty of force to compress a decent spring, assuming a post gearbox reduction. It all comes pre-made, takes little modification, and is actually quite light.
| hurdler or herder? | XXShadowXX | Technical Discussion | 17 | 08-01-2008 17:16 |
| RC Powered on 7.2v backup | chris31 | Electrical | 10 | 17-10-2006 11:02 |
| Gas powered engine horsepower equivalent to electrical motor horsepower? | Elgin Clock | Motors | 30 | 22-08-2004 20:44 |
| Bosch Drill Motor Clutch Spring Dimensions?? | aaronbr28040 | Motors | 3 | 18-02-2004 19:52 |
| Powered OI input | EricS-Team180 | Programming | 7 | 28-09-2003 21:23 |
