Go to Post Batteries don't help you if they're lying on the field. - Kevin Sevcik [more]
Unread 10-01-2008, 13:19
borabora borabora is offline
FRC #0334
borabora will become famous soon enoughborabora will become famous soon enough
What is the maximum Number of motors allowed?
I cant find the maximum motor limit in the manual... Is there one?
All i found was
<R59> Additional motors specifically permitted on 2008 FRC ROBOTS include:
All motors, actuators, and servos provided in the 2008 Kit Of Parts,
HITEC HS-322HD servos,
FIRST Tech Challenge (FTC) servos (Innovation First part number 276-2162),
FIRST Tech Challenge (FTC) motors (Innovation First part number 276-2163),
One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12 in addition
to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
This rule makes it seem like there is only a limit on the number of CIM motors you can use. So you can use as many other motors as you want?
Number of members allowed in a team Bomberofdoom General Forum 24 21-08-2007 15:30
Pit Max Number Allowed seg9585 Rules/Strategy 7 16-02-2006 11:29
Maximum Number of Capped Tetras? thoughtful Rules/Strategy 26 15-01-2005 00:32
Is there a maximum number of stacked tetras? Dr.Bot Rules/Strategy 4 12-01-2005 13:15
Maximum Number of Points Melissa Nute Rules/Strategy 49 13-01-2003 16:11
