roll pin into output shaft
hey guys we are trying to put the roll pin into the output shaft but we cant seem to get it in we tryed expanding the metal with heat ,oil and we already broke 2 of the roll pins we cant get it in Any other temas having problems with this
Re: roll pin into output shaft
We're having the same problem, and totally destroyed two of the roll pins trying to get it in. Actually we order some new pins but they only come in big bunches. Like you asked before, how do you get it in? We tried hammering lightly, using a rubber mallet, and using oil as liberation.
We assembled our transmissions a few days ago - the roll pin went in fine on one, broken on the other. Just make sure you get it straight before forcing it in with either a hammer or a press.
When putting the roll pin in, the less hits the better. If you watch the assembly video on andymark.biz, you'll notice he gets it in with about 4-5 hits. We tried it slow at first and mushroomed the head, then gave it 3 good quick wacks, WAHLAH! perfect.
I agree with Chuck, you have to do a few hard hits or else it will flatten the top. The first one went in fairly easily for me, but you have to bend it back with a pair of pliers so it stays straight. The second time, I didn't bend it back and it went in way crooked. I ended up breaking off the bent and mangled mess, and after that there was only 1 or 2 mm left on each side, which happened to be enough to hold the gear on.
We started it with a few light taps and finished it off with a few big hits.
I first tried using an Arbor press which pretty much mangled the first pin, and then I used their suggestion of light taps with a hammer. It worked rather well for me, though it took awhile. It mushroomed a little bit but it went in and is holding the gear in rather well.
maybe drill the hole out a few thou?
The key to getting a tight rolled pin in is to make sure it starts to fold in on itself (axial). We noticed that on end of the pin was slightly more tappered than the other. A sqeeze with pliars will encourage the fold as you smack it with a hammer. It should go in fine after that. If you don't get an overlap it just plain won't go in.
#10
A really big hammer!
Our team had the same problem. We stated it with a little hammer tapping and then used a vise as a press to finish it off. |
#11
Yeah we just did those today.
We just used a Vice to get the pin through the hole and then we hammered it to get it all the way through. However the end that we hammered mushroomed we tried our best to fix it but the gear that rests on it has a slight wobble Is that bad? |
#12
Had some problems, but got what seemed like a reliable method:
1. Opened the holes a bit with a punch. This should allow the pin to fit in slightly at first. 2. Lightly tapped it in with a steel hammer, until it is set in the shaft and won't fall out. 3. Switch to a hammer with a softer head material (not too soft though), and continue tapping. 4. If the pin begins to deform or bend, shape carefully back into place with pliers or a hammer. You might have to do this a couple times. Should work, just be careful with it and don't try to hammer it in with all your force. |
#13
Part of the problem is that the roll pin is .100 (or thereabouts), and the shaft hole is about .080. Now the BOM for the Toughbox states that roll pins are 3/32". That correlates to .09375. So firstly, the Roll Pins are oversized from the appropriate dimensions. Secondly, the holes are undersized from a proper tolerance perspective of an interference fit with those materials. A proper fit for a split or spring type pin should only interfere a few thousandths, not 15-20 thousandths. Another reason to doubt the quality control folks.
#14
We had the same problem. We got one pin in, then bent 5 more (there are 2 teams at our school so we were using all of our pins up >.>) We bought some others from the hardware store and ended up drilling out one side of the shaft and put in our new ones, and now we have 4 good gearboxes. It was one hell of a time waster though, we must have spent three hours last Saturday on them.
| Beware - transmission output shaft is not 5/8"! | jskene | Kit & Additional Hardware | 30 | 13-02-2006 14:01 |
| diameter of transmission output shaft | sj31419 | Electrical | 5 | 17-02-2005 22:09 |
| Cutting the output shaft | Kevin A | Technical Discussion | 2 | 18-02-2003 01:47 |
| Securing hex shaft to drill output | D. Gregory | Technical Discussion | 6 | 24-01-2003 14:05 |
