Go to Post The robotics, strategics, and technology make up the higher wavelengths, the adrenaline of competition the midband, and the low frequencies that pull at the heart, well that's the people. - John Wanninger [more]
Unread 10-01-2008, 17:12
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
Controller help!!!!
i need to adjust the voltage sent out to my robot from my controller. for ex. the reason i would need this is so when you push your controller forward it takes alot of power to get your robot to start moving, but after it has started it takes off because there is less resistance than there was initially. well i want to change that so that the robot gradually accelerates,and doesn't just quickly take off. I dont know if that explains it well enough but if you can help me at all that would be great!
Regular Xbox Controller...HELP! lostandconfused Control System 1 13-02-2007 14:29
Playstation controller code help haywirerobotics Programming 4 25-01-2007 00:16
EduBot Help, RC Controller Allison K Robotics Education and Curriculum 5 29-03-2004 16:48
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Help - Gear Motor Controller dteshome Motors 17 13-05-2003 15:13
