Go to Post One thing that always strikes me at FRC competitions is seeing the little nerds reveling in the same kind of self-celebrating bravado the high school jocks have always indulged in. - gvarndell [more]
Unread 10-01-2008, 18:15
KoulFireChick's Avatar
KoulFireChick KoulFireChick is offline
Jack
AKA: Jill
FRC #1510 (Wildcats)
KoulFireChick will become famous soon enough
Send a message via AIM to KoulFireChick
Design Pro's and Con's
Team 1510 still has yet to put a design together but we do have a bunch of things put together. We picked our robot was going to hurdle amd came up with basics on how it was going to do that, so here are some of the one's I like I want to know are there any other Pro's and Con's with any of these idea's that you see.
Scissor Lift
Pros
-lightweight
-reliable
-top incline
-simple concept
Con
-high CG
-complex design
-flimsy
-heavy (depends on materials)
(cata)Launching mechanisms
Pros
-can be small
-low Center of gravity
-a fraction of the weight (inclined plane)
simpler solution (mechanical)
Cons
-potential game play
telescoping lift
Pros
-reliable
-experience
-adjustable heights
-fast up/down
-lightweight
-save power
-possible other teams penalties
Cons
-high center of gravity
-potential for damage
so please if there are any other pro's and con's do tell, or if you have any ideas that we could use feel free to shair
in robotics it's all about the "things" between the guys. When your a girl you're nothing more then a bistanderd forced to watch what really goes on during build season
Unread 10-01-2008, 20:37
JessicaM29 JessicaM29 is offline
FRC #2595 (Illuminati)
Team Role: Student
JessicaM29 is an unknown quantity at this point
Re: Design Pro's and Con's
can anyone post up example of these things cause i am sort of confused on these type of strategies... if you want to call hem that.what ways are you guys doing?
Unread 10-01-2008, 21:07
Jack
AKA: Jill
We want to hurdle and these are desige ideas on how to hurdle that ball
Unread 10-01-2008, 21:54
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
Team Role: Leadership
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
Originally Posted by KoulFireChick View Post
Scissor Lift
Pros
-lightweight
-reliable
-top incline
-simple concept
Con
-high CG
-complex design
-flimsy
How does this work?
For the most part, you are just listing properties of the lifts mechanisms. Each has its own advantages and disadvantages. It is your overall strategy that should determine which you should use. That being said, scissor lifts tend to be very flimsy...
crate design and construction oreocookeee Technical Discussion 20 18-12-2004 02:32
Vetting and Idea: Modular Field Design... Justin General Forum 19 16-06-2004 15:46
Gear and Timing Pulley Design Resources Madison Technical Discussion 2 08-05-2003 21:01
New forum for websites and design! activemx CD Forum Support 6 21-09-2002 12:07
Design Your Future Award (and others..) archiver 2000 3 23-06-2002 22:44
