Go to Post I didn't say this! - Max Lobovsky [more]
Unread 10-01-2008, 21:56
burningblane burningblane is offline
FRC #1875 (Catagory 6)
burningblane is an unknown quantity at this point
Send a message via AIM to burningblane Send a message via MSN to burningblane Send a message via Yahoo to burningblane
Couple of questions?
Hi teams,
I had a few questions that team 1875 was wondering about the game.
Do you know if we can control/tap your opponents balls?
Can you pass balls over the center divider?
Does a trackball have to make a complete lap to get points of does it have to just cross one of the finish lines?
Is it considered trapping if you pin your opponents balls in teh corner without touching them?
Thanks for answering these questions guys and good luck with your robot
Unread 10-01-2008, 22:08
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
Re: Couple of questions?
Most of those questions can be answered from reading the manual.
In order of the questions, rule <G29>,
There is no rule saying you can't,
Rule <G12> and <G13>,
and finally just look at the Possessions Definition for the last question.
Unread 10-01-2008, 22:10
jimmythetulip22's Avatar
jimmythetulip22 jimmythetulip22 is offline
AutoCad God
FRC #2189 (The Wolf Pack)
Team Role: Animator
jimmythetulip22 will become famous soon enough
Lets see,
for the first one I am not sure, I think you can but you would be scoring for them so thats not so smart
Yes, you can pass the ball over the center divide, but that seems like a lot of work to do,
And you only score points for having both the robot and the ball cross YOUR finish line, not both (the only time you get points for scoring through their finish line is in hybrid mode,
And finally, I think blocking their ball is probally illegal and stupid because if your blocking their ball then you cant be scoring!
Check the rules but I think these are all right!
Life is like a roller coaster.
Sometimes you go up,
Sometimes you go down,
Sometimes, you fall off and die!
Unread 10-01-2008, 22:17
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Originally Posted by jimmythetulip22 View Post
Lets see,
I would check the references given above, so you can determine which of these answers were wrong.
(since 2004)
Couple of quick questions. ZackS Rules/Strategy 3 07-01-2008 11:29
[FVC]: Couple of Questions Eragnok FIRST Tech Challenge 9 19-03-2007 16:39
Couple questions Minitruck1506 General Forum 11 08-03-2006 01:34
couple of questions... archiver 2001 5 23-06-2002 22:48
A Couple Questions about Chairman's Award ben_whly Chairman's Award 4 26-01-2002 18:24
