Using More that 2 Flight Sticks
I have some questions regarding the use of flight sticks.
Can we use diffrant flight sticks that what is provided in the kit? Are we allowed to use more that 2 flight sticks? Will we be permitted to use something other that a flight stick? Can we attach a battery to the mounting panel to allow the sticks to be powered without a wall adapter? |
Re: Using More that 2 Flight Sticks
Yes Are we allowed to use more that 2 flight sticks? Yes Will we be permitted to use something other that a flight stick? Yes Can we attach a battery to the mounting panel to allow the sticks to be powered without a wall adapter?[/quote] I don't think so...check the manual? |
Thanks that cleared up some things our team was wondering about.
If you guys need any coding help, drop me a line. |
In Competition: No At School: Yes, but notice that any voltage changes will cause your analog sensors to mess up on your OI like your joysticks, so be careful, and I highly advice you to make a voltage regulator that will ensure a steady voltage. |
The OI has an internal LM7805 or similar regulator IC. Voltage input is already regulated.
Thank you all for your input. It was very helpful.
One more thing to add: If you're using something like the USB Chicklet (http://www.ifirobotics.com/usb-chicklet.shtml) on your operators console, there is no place to plug it in, and you MUST bring a battery for it to the competition. the OI gets it's power from the "competition" port, but no other independently powered devices will!
If it is regulated, then the regulator is not very good... Last year we hooked up 2 9V batteries in parallel (so the total voltage was still 9V) but all of our analog stuff was messed up.
#10
Voltage regulators have a parameter called "Dropout"- the input voltage at which regulation no longer occurs.
A 78xx series regulator requires an "overhead" - the voltage difference between input and output - of something like 2 or 3 volts to avoid dropout. Low-Dropout (LDO) regulators exist, with overheads of a fraction of a volt. Your 9 volt transistor battery was very close to the dropout limit for a 7805 regulator already. If you draw more current from the battery tha its rating - I think it's 20 mA for that kind of battery - the battery output voltage can sag (get lower). You may want to check what current the OI draws, either by looking at the specs or by direct measurement, and decide if a two 9 volt batteries in parallel is sufficient to power the OI reliably. Don |
| using more motors | Aren_Hill | Motors | 6 | 13-02-2005 17:44 |
| using more motors | Aren_Hill | Technical Discussion | 2 | 13-02-2005 15:52 |
| Using the edu--erm, Robovation for more info? | Billfred | Control System | 8 | 18-07-2004 21:50 |
| Is 'using a smaller cylinder' really that easy?? | mjt902 | Pneumatics | 4 | 29-01-2003 16:13 |
