Go to Post Don't put any weight into the OPR. It's ugly and its momma dresses it funny. - wilsonmw04 [more]
Unread 11-01-2008, 11:34
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Rookie Year: 1996
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: Bumper Rule
Originally Posted by Elgin Clock View Post
With a give maximum sized robot of 38" x 28" giving us:
((38*2) + (28*2)) = 132" perimeter
2/3 of 132" = 88"
Technically I guess you can only cover 88" worth of sides if you wanted to.
Some people tend to cover just 3 sides of their robots so using the 2 most basic configurations of robot design...
1) 38+38+28 = 104" (38" Sides & 28" Rear)
or
2) 28+28+38 = 64" (28" Sides & 38" Rear)
In configuration 1, you are good.
In configuration 2, you are not.
If you design your robot to be a wide base (example 2), and your widest part of your robot is facing forward, and you leave that unbumpered, I guess you are breaking a rule.
That kinda sucks...
Hey Elgin, try doing that math again on #2.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 11-01-2008, 11:23
Rookie Year: 1996
Re: Bumper Rule
Originally Posted by Compnerd View Post
Do the bumpers have to surround the frame/base of the robot completly, or can there be a gap? My team has looked at the rules, and everyone interprets it slightly differently. Anyone know??
To answer your original question - yes, there can be gaps as long as you cover 2/3 of the perimeter, and no bumper segment can be less than 6" long.
Unread 11-01-2008, 11:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Bumper Rule
Specifically, the rule states that a STANDARD bumper as defined in Fig. 8-1 must be no shorter than 6 inches. Since they also do not want "hard" bumpers in the corners, you must place a vertical pool noodle to soften the corners of the side or front bumpers such that it covers the corner.
The extra vertical pool noodle that isn't part of the STANDARD bumper cannot count toward the minimum 6 inches. Though it is unfortunate, this is the only interpretation of this rule I can come up with.
GitHub
Unread 11-01-2008, 11:45
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Bumper Rule
Can you quote the rule stating that you "must" use a vertical pool noodle on the corners? I've looked and can't seem to find it anywhere...
Unread 11-01-2008, 12:00
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Re: Bumper Rule
There is nothing requiring that a vertical pool noodle be used in the corner, but because the only thing that can be used in the corner is a pool noodle or cloth piece of bumper (and not wood, or other "hard" materials), most teams cut a pool noodle the height of a bumper and stand it up in the corner.
Figure 8-2 on page 10 of THE ROBOT shows exactly the scenario I am describing in the top left corner of the view of the robot on the left.
"If needed, a pool noodle corner can be wrapped into bumpers - but only pool noodles & cloth may penetrate corner space"
And lower left on the image....
"hard" bumper parts do not extend into the corners."
Basically what this is saying is that you can not "miter joint" the wood going around your robot behind your bumpers.
I'll try and get a good picture of what we have done and has been accepted in the past with these rules (which have not changed much, if any over the years of bumpers - other than the REQUIREMENT to have them this year as opposed to previous years.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 11-01-2008, 12:07
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Bumper Rule
... you may place a vertical pool noodle to soften the corners of the side or front bumpers such that it covers the corner.
Fixed your post.
The note in Figure 8.2 says, "if needed, a pool noodle corner can be wrapped into bumpers - bou only pool noodle and cloth may penetrate the corner space"
(since 2004)
Unread 11-01-2008, 13:00
JesseK's Avatar
FRC #1885 (ILITE)
Re: Bumper Rule
Yea my bad. The point of the post was to clarify that the vertical pool noodle isn't part of a standard bumper by definition, therefore the vertical pool noodle should not be used in the 6" minimum dimension. I've thought about this several times due to the fact that our team this year is going with an open-front design and due to the nature of the bumper rules we unfortunately cannot have bumpers on the front, at all.
GitHub
Unread 11-01-2008, 13:01
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: Bumper Rule
Heres a quick question:
What if one were to put bumpers on their robot in such a way that they fit all regulations and made contact within the bumper zone, but also extended below the 2.5" mark??
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 11-01-2008, 13:07
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Bumper Rule
If it was below 2.5" it would not fit regulations.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
New Bumper rule interpretation - straight from the lead inspector Gary Dillard Rules/Strategy 17 12-03-2007 14:56
bumper coolguybigt Technical Discussion 4 27-02-2007 16:40
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
Rule G11 and Springs Rule mtaman02 Technical Discussion 3 23-01-2004 17:43
Bumper Rule <R17> Veselin Kolev Rules/Strategy 10 23-01-2004 09:58
