Re: Can't mount the gear tooth sensors
The only way to mount to the clear cover and reach the 50 tooth gear at the bottom is to use spacers. I tried 3/4 inch spacers, and that was a little too long. Half-inch spacers may not be enough. In the end we drilled the aluminum plate and mounted with a few plastic washers. Then it worked great. See the pictures above. |
We ended up basically carrying the holes from the lexan shield over to the aluminum shield and everything works great. Thanks for your help.
| Help with the Kit Gear Tooth sensors | Keo-san | Programming | 9 | 20-02-2007 08:07 |
| dumb question: Where do we get the gear tooth sensors from? | waialua359 | Programming | 6 | 30-01-2007 22:45 |
| where can we buy hall effect sensors or gear tooth sensors | amirjpl | Electrical | 3 | 13-02-2006 11:02 |
| Gear Tooth Sensors | et1337 | Electrical | 7 | 28-01-2006 22:48 |
| Accelerometer vs Gear Tooth Sensors | zdeswarte | Electrical | 4 | 22-01-2005 15:35 |
