Go to Post If you have time at a competition, stop and thank some of the people wearing the crew shirts. They are working very hard to make sure the competition goes as smoothly as possible. - Greg Young [more]
Unread 11-01-2008, 16:30
1594code 1594code is offline
FRC #1594
1594code is an unknown quantity at this point
How do you wire the gear tooth sensor?
Hi,
Our team hasn't used sensors other than the CMU camera and limit switches before. We have an idea how to program the gear tooth sensor, but how do you wire it? PWM cables seem to fit well, and I see that they are what the manual recommends. How do you fasten the PWM cable into place on the sensor board? Soder?
Where on the RC or robot do you connect the PWM cable that supplies the 12Vdc operating voltage?
And the +5 cable connects to a Digital Input port on the RC, no?
Any advice would be appreciated!
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Sensor Nathan Programming 4 12-01-2008 15:09
How to integrate Gear Tooth Sensor magical hands Programming 0 18-02-2007 17:43
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Mounting the Gear Tooth Sensor??? blue_crew Electrical 3 09-02-2006 13:53
