Go to Post By seeing other robot designs, teams can plan before hand on how to defend or defeat it. - Don Wright [more]
Unread 11-01-2008, 17:26
Skifanatic's Avatar
Skifanatic Skifanatic is offline
AKA: Matt
FRC #0348 (NHS Robotics)
Team Role: Mechanical
Rookie Year: 2007
Skifanatic is an unknown quantity at this point
Send a message via AIM to Skifanatic
Accumulator Mounting
Can the accumulator be mounted after the regulator, or does it have to be mounted before?
Unread 11-01-2008, 17:53
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
Team Role: Leadership
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
Re: Accumulator Mounting
please refer to page 14 of the 2008 pneumatics manual, found under section 8 of the 2008 FRC manual
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 12-01-2008, 18:29
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
They can be on either side of the regulator, but they will be more valuable to you on the 120 psi side (before the regulator) than on the 60 psi side (after the regulator, since they can effectively hold "more work" since the same volume of air is at a higher pressure.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Mounting encoders? waialua359 Technical Discussion 4 13-02-2006 01:57
Mounting Lasers??? Mandy_Candy General Forum 15 17-02-2004 21:26
Sideways mounting srjjs Electrical 13 25-01-2003 20:31
SMC Accumulator & Cylinders archiver 1999 3 23-06-2002 22:06
