Team Update #2
Posted 11 January 2008: http://www.usfirst.org/community/frc...nt.aspx?id=450
What to say about it? Section 10.2.8.1 The 2008 Trackballs require some care in assembly and inflation. Each Trackball consists of two parts: a Bladder and a Cover. The bladder has a 120cm diameter and is made of 2500g PVC. |
Re: Team Update #2
Is this as much of a bombshell to everyone else as it is to me? Section 6.3 says the balls are approximately 40", and ours came up a couple inches short even with the help of the compressor. 120cm is more than 47"... I'd think this would make a HUGE difference for a lot of designs, both in terms of the size of your gripper, and how much this thing is going to bounce if you stretch it out 20% more. I'm hoping to see this re-clarified soon.
Re: Team Update #2
Also, on that note, I don't see any balls with plain blue or red covers. They're all some sort of hyper-large sports ball and they're all really expensive. |
Re: Team Update #2
Re: Team Update #2
I noticed that after i posted the link. I am going to try to verify that the bladder was not different than this one and repost when i can verify correctly.
Re: Team Update #2
Why can't FIRST provide a manufacturer and Part #? This would ensure that everyone gets the proper ball. I did notice last weekend that there was a 40" ball and a 120cm ball mentioned, perhaps you buy the 120cm and only fill it to 40" (i.e., just enough to fill the cover)?
Re: Team Update #2
Re: Team Update #2
I personally like the new <G36> because it doesn't incur a penalty on a robot that has been disabled and cannot move. A penalty would just add insult to injury.
#10
Re: Team Update #2
Re: Team Update #2
Re: Team Update #2
There is absolutely no way that the balls are 47". The cover that came with them would burst at the seams.
#13
Re: Team Update #2
I like that they clarified that disabled robots may be pushed out of the path of travel without penalty. This was a point of discussion on one of the threads here.
I dislike that they reused <G36>. The OLD <G36> was the height restriction on robots in the opponent's home stretch. Update 1 said <G36> has been removed. Update 2 says <G36> disabled robots may be pushed out of the way w/o penalty. I think that <G36> should have simply been gone, and the new rule should have gotten a new number, rather than reusing the number. <G38> and <G40> regarding impeding a robot and "bumping to pass" are now only applicable during teleoperated mode. I think this is good, because I think no team would be attempting to implement a "bump to pass" during autonomous. It also opens up some potential defensive strategies which have been discussed elsewhere (i.e. blocking during the hybrid mode). <G42> now applies the protection of a robot in the process of hurdling to both the robot and the trackball. The inspection checklist has had "Robot Class" removed -- this was obviously just left in when copying from last year. <T15> should make qualification matches go a little faster. During elimination matches, the higher seeded alliance can position their robots after the lower seeded alliance positions their robots; during qualification matches, alliances position their robots simultaneously. |
| Team Update 16 (3/16) | Joe Ross | General Forum | 2 | 17-03-2005 16:34 |
| Team Update #9 | Curtis Williams | General Forum | 10 | 03-02-2003 20:37 |
| Team Update #7 Up | Steven Carmain | General Forum | 5 | 27-01-2003 23:15 |
| Team Update #3 is up | pavelthegeek | Rules/Strategy | 8 | 24-01-2002 14:51 |
