Go to Post No email, no telephone, no FIRST. I can't wait.... - RoboMom [more]
Unread 12-01-2008, 00:33
calvin1631 calvin1631 is offline
FRC #1631
calvin1631 is on a distinguished road
Confused about air usage
I am confused about air usage. we were setting up a prototype pneumatic system using a 3/4" x 10" cylinder, and 4 tanks. We pumped up the tanks to 100psi and had the pressure limited to about 35psi to the cylinder. I only got it to go in and out about 9 usable times. I saw a formula to calculate this related problem and found that we should technically be able to at 120psi, with a 3/4" x 10" cylinder, have 20 actions. What am I doing wrong?
Unread 12-01-2008, 01:04
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: Confused about air usage
We calculated that at 120 psi we only could fire our cylinder out once then back in once before we had to recharge. If we fired it again yes it would work but you wouldn't have MAX psi in the cylinder so the power of it would be significantally less.
Unread 12-01-2008, 04:33
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
I believe your calculations are shown by your experience. The 20 "actions" you calculated theoretically transfers to the actual 18 you got, 9 ins and 9 outs, if I'm understanding you correctly.
Unread 12-01-2008, 11:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Don't forget you have hose between the solenoid and cylinder which uses up molecules of air each time the solenoid is fired.
Unread 12-01-2008, 17:10
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
If you wanna increase the psi from 35 you do it through the pressure guage that comes out of the tanks, the maximum can go up to 60 psi
Unread 12-01-2008, 21:28
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Using your number of 100 psi, 35 psi, and 10 inch stroke, I calculate 11 cycles (in and out = 1 cycle) at 35, but with 4 tanks you should still get several more at lower pressure. A few things to consider:
Not sure why you said 100 psi versus 120. The pressure switch (and the relief valve on the compressor) will cut out at 120, so if you're not getting there it seems like you may have a leak somewhere. Pressurize the system and let it sit for a few minutes to see if it bleeds down. Try it with the actuators in each position; you may be getting a leak on the side of the solenoid or piston that is not under pressure when you initially checked the system. Also, the gages are not very accurate, so you should leave some margin to account for that (and the extra air in the tubing).
Close enough to taste it, too far to reach it
Confused about Atlanta Rick-906 Championship Event 6 21-03-2007 18:19
Confused about potentiometer values Kirk Technical Discussion 4 11-03-2006 16:29
Confused about Interrupts karch Programming 11 31-01-2005 09:51
Confused about Camera AnkurG Programming 5 26-01-2005 19:50
Confused about chat.... Elgin Clock CD Forum Support 5 15-11-2001 07:58
