Go to Post It's not fair. it's not right, but stuff like this happens. If you don't get picked for finals tomorrow, get in those stands and cheer for those who did. Remember, this is FIRST. - wilsonmw04 [more]
Unread 12-01-2008, 12:57
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
Rookie Year: 2007
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
pic: Pulley?
Unread 12-01-2008, 12:59
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: Pulley?
It might help to know how big it is supposed to be, and what the requirements for it are...for example, does it need to be a specific width, or could be anywhere from 2" to 6" wide? does it need to have a specific diameter inside for the shaft, and outside for the cable/wire/whatever to roll onto? Is there some weight limit you have in mind? Do you have welding capability, or a shop in town that could weld steel or aluminum, if you could cut a tube and make the "washers" for the ends? and is there some other way to attach it to a shaft?
Unread 12-01-2008, 15:13
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Re: pic: Pulley?
We (team 612) used to have some 6" Delrin rod that would be perfect for this application. Mating the rod to a live axle might take some thought, though.
According to the nifty FIRST team info database, 2158 is an Austin, TX team. Is there someone in this area who could help this team out?
Unread 12-01-2008, 16:58
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: pic: Pulley?
Dyano,
When do you need this, and what exact dimensions and material are you looking for? We've got a lathe, broaching set, and a load of aluminum stock. If it's not going to weigh more than a pound, we could turn it out and mail it to you. If it's heavier, we'd probably have to figure out a way to run it up to austin. We've got an ex team member that's attending UT that might not have left Houston yet, however, so let me know ASAP what we're looking at here, and I'll try to hook you up.
Unread 12-01-2008, 17:05
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: Pulley?
Aside from making it from 3 pieces (use 3 long screws and nuts to hold the ends together), or having Kevin's team make one up for you (Note that "Priority Mail" from the post office has a flat rate box, send anything that fits in the box for just under $9. Even lead plates.), you can find Electrical Wire on spools like this. Go look at Radio Shack to see small versions of what I mean, an electrical supply house (or Home Depot/Lowes/hardware store/etc) will have them in a variety of sizes, and once they sell the wire off a spool they usually throw it away. Or if a parent is an electrician.
Good luck,
Don
Unread 12-01-2008, 18:59
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: pic: Pulley?
hm... It depends on how big that thing is really. if it is fairly small, not much. but if its over 6" in diameter, might have to have a machine shop do it. unless you guys have a lathe and some crazy long drill bits.
-vivek
"we don't build robots, we build people"
Unread 12-01-2008, 19:35
AKA: David Yanoshak
Rookie Year: 2007
Re: pic: Pulley?
Thanks everybody for your suggestions. We decided on either getting a plastic spool, or making our own out of aluminum; using aluminum tubing and aluminum discs similar to what squirrel mentioned.
pic: Team 48 Drive Pulley A_Reed Extra Discussion 2 29-01-2007 12:26
Large CIM motor pulley size/series? Tim Skloss Technical Discussion 3 09-01-2007 22:36
big CIM pulley Rickertsen2 Motors 1 18-01-2006 11:41
Timing Belt and Pulley Joe_Widen Technical Discussion 4 16-01-2006 13:41
Gear and Timing Pulley Design Resources Madison Technical Discussion 2 08-05-2003 21:01
