Go to Post I don't play with robots, it's much more serious than that. - Al Skierkiewicz [more]
Unread 12-01-2008, 13:58
whlspacedude's Avatar
whlspacedude whlspacedude is offline
AKA: Will
FRC #1529 (Cyber Cards)
whlspacedude is just really nicewhlspacedude is just really nicewhlspacedude is just really nicewhlspacedude is just really nice
Send a message via AIM to whlspacedude Send a message via MSN to whlspacedude Send a message via Yahoo to whlspacedude
Mech Wheel Programing
This year we would like to try mech drive with 1 joystick. this joystick has x,y and z(twist) on the stick and t for speed.
i have no clue how to do mech programing and would really like some help with it .
we would like strafe with the x axis and turn with the z axis.
also we would like speed control with the t axis
how would we go about doing this in easyc?
Some people are like slinkies they are only good for 1 thing... pushing them down flights of stairs
1529 mph = 4 109 952 furlongs per fortnight
Unread 14-01-2008, 10:42
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Mech Wheel Programing
While it's not easyC, check here: http://www.chiefdelphi.com/forums/sh...m+drive+co de
The basic idea for either an omnidirection or mechanum drive train, each wheel will have a certain speed that it needs to be driven to contribute to the desired combination of f/b motion, strafing, and turning. You calculate these for each wheel, and sum them up.
Code:
fr_pwm = speed-turn+strafe;
fl_pwm = speed+turn-strafe;
br_pwm = speed-turn-strafe;
bl_pwm = speed+turn+strafe;
You may have to reverse some of these due to how your motors are installed, and you would be best to do a lot of bounds checking and be careful with variable types to make sure you don't have wraparound errrors.
Unread 14-01-2008, 12:47
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
Rookie Year: 2007
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
What Kaszeta said is correct; however, our team decided we also wanted to scale the values. What we came up with was to take the initial inputs, change the range to (-127)-(127), add them together, then scale the sum by a factor:
The factor = Max ( |speed|, |turn|, |strafe|) / (|speed| + |turn| + |strafe|)
We used this code last year, and it seemed to work pretty well.
Unread 14-01-2008, 15:43
AKA: Will
Being new to "real' C programing (have a knowledge of BASIC) I really would like to have a .ecp file to look at. thanks for the other links!
Unread 14-01-2008, 15:57
kaszeta's Avatar
http://www.chiefdelphi.com/forums/sh...ad.php?t=51704 should take care of this.
Good luck.
Unread 14-01-2008, 15:58
AKA: Will
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
paper: Rat Pack and Mech Warriors Match Scouting Sheet, Revised Lisa Perez Scouting 1 08-03-2006 09:00
Attn: Mech Designers, Beta Testers Needed! JVN General Forum 18 13-12-2005 20:59
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
