Go to Post Like a moth to a flame, true FIRSTers are attracted by the Victor instead of the Banner. - Rich Wong [more]
Unread 12-01-2008, 14:14
Trav-O's Avatar
Trav-O Trav-O is offline
THE PROGRAMINATOR
AKA: Travis
FRC #0510 (Hawaii 5-1-0)
Team Role: Tactician
Trav-O is infamous around these partsTrav-O is infamous around these parts
Build problems: MPLink 4.15 Linker... help?
Hey guys! we're having some problems over here...
I'm putting the programming software on my laptop (thinkpad T series runing Vista) and i've ran into some problems
ok, I have MPlab up and running with the source code and i'm pretty sure the compiler's ok, but his is what happens when I try to build:
once it gets to MPLINK 4.15 Linker, i get an error:
Error - Coff file format for '.main.o' is out of date
Errors : 1
link step failed
Debug build of project 'C:\Users\....\FrcCode.mcp' failed
Preprocessor symbol '_DEBUG' is denied.
Sat Jan 12 14:00:37 2008
FAILED
any ideas?
Be safe!!! OR YOU MIGHT GET INJURIES!
Unread 12-01-2008, 14:25
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Build problems: MPLink 4.15 Linker... help?
That usually means the object files were compiled with mixed versions of the compiler, i.e., version 2.4 vs. v3.x.
What version of the compiler are you using?
The one that came in the KOP is v2.4, but the downloadable version is 3.10 or 3.15.
Unread 12-01-2008, 14:26
Trav-O's Avatar
THE PROGRAMINATOR
AKA: Travis
allright, i'll reinstall everything and see if that works
EDIT
Yuup, I reinstalled everything straight off the CD and it's working
Mplink error jimmyrock88 Programming 2 14-11-2007 15:50
linker error help Rickertsen2 Programming 2 13-02-2006 17:53
MPLink Error cloudago Programming 2 01-02-2005 23:00
Linker Error help Dinush Programming 3 11-02-2004 21:44
