Go to Post "FIRST isn't what it used to be anymore. It makes me upset and it makes me question many things." - Arefin Bari [more]
Unread 12-01-2008, 14:59
Semicolon's Avatar
Semicolon Semicolon is offline
Semicolon will become famous soon enough
A different kind of gear tooth question
Can the gear tooth sensor be used to detect something other than gear teeth? Our team is interested in just sticking some screws and nuts equally spaced around a wheel and line the gear tooth sensor up to detect the screws. We would probably need some iron based nuts and bolts, but it seems possible. Will that work? (note: We would use the sensor that came in the kit)
Stay with me here...
Everyone knows that Time = Money and Knowledge is power right? It is also known that Power = Work / Time. So then we substitue Power and time so Knowledge = Work / Money. Then we solve for money and get that Money = Work / Knowledge. So, As Knowledge approaches 0, the more money is made regardless of how much work is done.
Now we know that the less you know the more money you make, even with close to no work!
dumb question: Where do we get the gear tooth sensors from? waialua359 Programming 6 30-01-2007 22:45
Question about Gear-tooth? Nicodemus Control System 4 21-01-2007 02:19
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
A different kind of support movement Carolyn Duncan Chit-Chat 5 16-09-2001 23:11
