Go to Post Ironically, I think the best testament to the program [Dean Kamen] founded and his ideals wouldn't be if he won a Nobel Prize. It would be if you did. - Kevin Sevcik [more]
Unread 13-01-2008, 00:34
shtylman shtylman is offline
some sort of programmer
FRC #2420
shtylman has a spectacular aura aboutshtylman has a spectacular aura about
Eclipse Plugin, Linux, and a Java Loader
So I have finally gotten around to packaging everything I have in the way of FIRST build tools. I reworked the old MCC18 Toolchain plugin for Eclipse and have brought it up to date as well as updated the error parser. These two tools will let you manage and build an FRC project using Eclipse. They are available for download through an Eclipse Update Site.
I have also packaged Jifi, my Java IFI Loader clone. This jifi release includes both a GUI and a command line version.
Both of these things, as well as more information on the Eclipse Plugin are available at: http://shtylman.com/frc/
If there are any questions, comments, or suggestions email or PM me and I will be happy to address them.
Unread 13-01-2008, 11:11
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
Re: Eclipse Plugin, Linux, and a Java Loader
Do I already need to have the C18 compiler running under wine on my pc in order to make this work or does the plugin take care of this for me? If not, can someone link me to a good tutorial to get the C18 running on my machine?
-Don
Team 548:
Attending National Championship, Genesee District, Detroit District 2, West Michigan District, Michigan Championship?
Unread 13-01-2008, 11:58
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
Team Role: Leadership
Rookie Year: 2007
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
-Don
There's no need for a tutorial -- setting up C18 in Wine is easy as pie. Just run the installer through Wine, and you're good to go.
shtylman: Thank you very much! I was using Eclipse with a simple makefile, but this will work much better!
Unread 17-01-2008, 13:51
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
Rookie Year: 2007
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
When I try to buld with eclipse, it seems to look for mcc18 in wine's system32 folder. thats not where mcc18 goes, it goes in C:\\mcc18.
Perhaps it's because I copied over the mcc18 folder from another computer instead of installing...
What should I do? Where can I change these paths?
Also, can I run wine prefixes besides home/.wine?
I'm running Ubuntu 7.10 Gutsy.
Unread 17-01-2008, 14:38
FRC #2420
When I made the plugin I did the best I could to try and peg it to the default installation settings most people will have. If those do not work, they can be changed through the project settings in eclipse.
I would like to know more about your problem, so if you could PM or email me some more info please feel free to do so.
~Roman
Unread 17-01-2008, 14:44
Ubuntu User
AKA: Brian
Rookie Year: 2007
You should use the installer; it sets the proper PATH variables for Wine to find the compiler executable. Both the C18 2.4 installer and the C18 3.10 upgrade installer worked perfectly in Wine when I tried.
Yes, you can run alternate Wine prefixes. The method behind doing so is covered in a sticky of general Wine-related information in the Wine forum at ubuntuforums.org.
WPILib and Eclipse Guy Davidson Programming 31 02-04-2008 16:59
Ifi loader and linux jasonpeinko Programming 4 08-01-2008 21:39
Eclipse Plugin Maintaineer? duane Programming 21 31-10-2006 22:34
White Paper Discuss: IFI Loader for Linux with compiling instructions CD47-Bot Extra Discussion 1 09-02-2004 16:46
IFI Loader for Linux rwaliany Programming 7 08-01-2004 01:48
