Go to Post If winning that individual match is more important to you than being there in the first place, then I believe you've got your priorities in the wrong spot. - Tom Bottiglieri [more]
Unread 13-01-2008, 08:55
Spencer E.'s Avatar
Spencer E. Spencer E. is offline
Android junkie
FRC #1305 (NNSRI Ice3 (cubed))
Spencer E. has a spectacular aura aboutSpencer E. has a spectacular aura about
Send a message via MSN to Spencer E.
Selecting bits from an analog input
Hey everyone, we are going to be using the USB chicklet and for buttons 5-8 it uses 4 bits from the AUX port on the joystick but I can't figure out how to select the bits from the actual output. Is there a simple way to do this or will I just have to do some math and figure out which output is being pressed by removing 128, 64, 32 and 16 from the output? Thanks in advance!
Unread 13-01-2008, 09:03
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Selecting bits from an analog input
There are several posts here on that if you search, but the easiest thing to do is use the bitwise AND operator. I also recommend writing a function that translates the AUX port to some global variables:
Code:
void Buttons(void)
   p1_sw_5=p1_sw_6=p1_sw_7=p1_sw_8=1;
   p1_sw_5=(p1_aux&1<<7)?0:1;
   p1_sw_6=(p1_aux&1<<6)?0:1;
   p1_sw_7=(p1_aux&1<<5)?0:1;
   p1_sw_8=(p1_aux&1<<4)?0:1;
where p1_sw_* are global variables.
(I wrote this to demonstrate the ?: operator to some students, you can also invert the logic test instead).
Unread 13-01-2008, 09:06
Spencer E.'s Avatar
Android junkie
Thanks so much!
Analog Input Errors... Tach'ko Electrical 1 11-01-2008 11:37
HELP: analog input Tottanka Programming 19 18-02-2007 19:27
Programming Analog Input from 2004 Controller Danny Diaz Programming 8 30-01-2007 22:44
Analog Input Trouble Matt Krass Programming 10 20-01-2005 21:09
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
