Go to Post Ask not what FIRST can do for you but what you can do for FIRST. - Koko Ed [more]
Unread 13-01-2008, 13:43
7-11number1 7-11number1 is offline
ROAR.
FRC #1711 (RAPTORS)
7-11number1 will become famous soon enough
Extending IR board connector wires
I assume everyone will be putting the IR received near the top of their robot. What type of connectors are you doing to use? Possibly DB9 (Serial) or would an RJ-45 network extensions? Running multiple PWM cables to the IR board doesn't seem like a good idea.
I'd like to put this connector either inside the tubing of the robot or protected by the robot PIC controller due to the potential for knocking off loose pieces in this years game.
Good Luck!
-Michael
Team Mentor: #1711
what is the four pin white connector for on the ir board ? Smaug Electrical 2 10-01-2008 23:37
Extending objects Booger Inventor 10 14-07-2006 13:04
height violation while extending gondorf Rules/Strategy 13 20-01-2006 08:33
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
pic: Vex before extending Not2B Extra Discussion 5 17-04-2005 22:01
