Hey everyone,
I was wondering if someone from arizona can tell me where I might be able to tell me where I might be able to get anderson connectors. I am not having that much luck. |
Re: Anderson Powerpole Connectors
We get them from here:
http://www.powerwerx.com/product.asp...071&CtgID=3579 but a rather expensive crimping tool is required for them. You can get them with a wire already attached from here: http://www.andymark.biz/am-0009.html |
Interestingly, I've been doing some research on these myself today... Here is what I've found:
http://www.westmountainradio.com/order_RC.htm Someone from another team referred me to http://www.alliedelec.com/Catalog/In...F&N=4294965246 Sorry I'm not from Arizona, but you can still order these ![]() |
Go here; http://www.kellrobotics.org/index.ph...=com_microshop AndyMark sells an assembly with 6 gauge wire and the large lug terminations. Kell Robotics sells the assembly for use on the battery charger. It has 10 gauge wire with step down butt splices for the 18 gauge wire on the chargers. Last edited by ebarker : 13-01-2008 at 20:55. Reason: additional info added for AndyMark and Kell |
| Anderson Connectors!!!! | cdennisxlx2 | Electrical | 9 | 06-03-2006 19:20 |
| Inventor Model: Small Anderson Connectors | CraigHickman | Inventor | 0 | 31-01-2006 22:55 |
| Shipping w/ Anderson Connectors | Sscamatt | General Forum | 2 | 20-02-2005 23:59 |
| How to take apart anderson connectors | M. Hicken | Electrical | 7 | 03-02-2005 08:53 |
| 45 or 75 amp anderson power products connectors to drill motors? | Andrew Wyatt | Motors | 2 | 20-12-2001 08:00 |
