Go to Post What's this about a robot that they speak of? Are we supposed to build one???? - ryan_f [more]
Unread 13-01-2008, 18:01
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
IR programming and wiring difficulties
Hey everyone i have a few questions that i would like to ask.
FIRST of all......i want to make sure that the IR wires should be plugged into the signal pin of the digital input robot controller.
I run easy C and when i run the terminal program on it, it tells me that the robot is sensing the ir sensor but all the inputs are always at one, and then when you press one of the ir buttons it changes the three that aren't being used to zero. Is this what is suppose to happen??
i also haven't been able to get the robot to respond with any of my programs can somebody give me an example program to work with to make this right??? thanks for all the help
Adam (progammer)
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
Need help Programming and wiring camera! Amisca Programming 1 14-02-2006 18:37
I'm having difficulties locating the programming code "gift" Flynn Programming 3 09-01-2005 22:01
Team issues and difficulties?....(not just technical ones) tribotec_ca88 General Forum 40 11-02-2004 10:36
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
