Go to Post a determined team can accomplish miracles. - Wayne C. [more]
Unread 13-01-2008, 21:00
Mikhail_Pham Mikhail_Pham is offline
Mikhail_Pham is an unknown quantity at this point
Using the IR remote to send radio commands to the robot
This sounds exploitive and probably illegal, but is it legal to use the robo coach to send IR signals to a robot operator control that would send radio commands to the radio receiver on the actual robot, eliminating any nasty bits about Ir signal strength during hybrid mode?
It would still only use 4 commands, but the signal strength would not be an issue.
Unread 13-01-2008, 21:05
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Using the IR remote to send radio commands to the robot
I believe all signals between the operator interface and the robot are cut off during autonomous (hybrid) mode, and if so this would not work.
Also, the fact that the IR board needs at least a 7 volt supply might also be a problem, because I don't believe you can get that much from your Operator Interface.
Good out of the box idea though.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 14-01-2008, 00:14
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
not true about getting the voltages. There are step up circuits that you can use with the receiver to get the correct voltage. I dont know if the OI recommends this, but it can be done.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Using the IR Receiver on the Robot LG67 Control System 1 06-01-2008 01:42
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
Programming the vex microcontroller to respond to commands on the serial port crashoverride02 Programming 1 20-10-2006 14:17
Can the pic controller send the data to pc? sunnyrx7turbo Control System 2 05-08-2005 13:14
