Few Questions regarding IR board
Hi,
my team managed to connect the IR board to a 9 Volt power supply with the 2 positive wires and the 2 ground (negative) wires. We trained a remote control too. Now we only need to connect the IR board to the 4 digital inputs on the RC. According to the manual there are 4 wires, each one for a digital input. We found those wires. And there are 2 other (last white and black) wires witch don't connect to anything. My question is: how do I do connect it to the digital port on the RC? With a PWM cable? If with a PWM cable so how do I connect 1 wire to it and where (there are 3 legs on the PWM cable)? We tried connecting the wire to the signal leg on the RC on the digital ports, but when we tested it on the on-line terminal (in EasyC pro) it didn't recognize the digital port. Another question: Will the robot be controlled only in some range (the IR receiver range)? If the robot turns 180 degrees it means I can't control it no more? Thanks in advance. Team 2217 Last edited by itsme : 14-01-2008 at 11:47. |
| Questions Regarding Rules | compasswilting | Rules/Strategy | 6 | 13-01-2007 14:56 |
| A few questions | Chase | General Forum | 15 | 14-08-2005 13:29 |
| A few questions... | Ryan Dognaux | 3D Animation and Competition | 3 | 19-02-2005 22:48 |
| A few questions | cheezewiz | Programming | 7 | 31-01-2004 00:02 |
| A few questions | goegan31 | Regional Competitions | 1 | 09-03-2003 20:32 |
