Compiler Error
When I try to compile my code it gives me this error. I've tried a few things and searched around for a few days and nothing seems to be working. Any ideas?
Errors Found. UTIL LIB.ASM Errors: 265 Warnings Reported: 285 Suppressed: 0 Messages: Reported: 0 Supressed: 0 Lines Assembled: 926 |
Re: Compiler Error
Unless you're writting assembler, I think you may be using the wrong linker. Make sure you have the C18 stuff installed and configured. We had this problem last year.
Re: Compiler Error
Also, make sure that if you installed mplab before c18, that you set mplab to use the one you installed under Projects > Select Language Toolsuite.
We've had that problem more than once in the past. |
| Error in code light on, trouble finding error | Bryan Herbst | Programming | 16 | 12-10-2007 21:59 |
| compiler error | SgtMillhouse648 | Programming | 5 | 05-02-2007 15:21 |
| stupid Array error: Error [1300] stack frame too l | Validius | Programming | 7 | 27-01-2006 10:53 |
| WEIRD compiler error | Rickertsen2 | Programming | 7 | 05-02-2005 14:09 |
| Confusing Compiler Error | UrsaMNet | Programming | 2 | 28-10-2004 14:32 |
