Go to Post 4 is kind of like 5 - Jaine Perotti [more]
Unread 01-14-2008, 10:27 AM
charlie1218 charlie1218 is offline
FRC #1218
Team Role: Coach
charlie1218 will become famous soon enoughcharlie1218 will become famous soon enough
Talking Converting Data EasyC
Hi all,
For a project I am doing seperate from FRC, i am making a mini darpa rover. The question i have is, how do i take a deg,min,sec value (ex. 172*34'53") and convert into decimals in programming. By hand it should be 172 + (34/60) + (53/3600). But alas I cant do that so easily in EasyC. Any suggestions?
Unread 01-14-2008, 01:57 PM
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: Converting Data EasyC
Put this into a user code block
answer = 172 + (34/60.0) + (53/3600.0);
When you do .0 it does Decimal Division instead of integer division
34/60 in integer division is 0 so you were doing 172 + 0 + 0
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 01-14-2008, 03:45 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You could also save the CPU a tiny bit of computational exertion by turning minutes into seconds first, adding the seconds, then converting the result to fractional degrees when you add things up at the end.
34*60 + 53 = 2093
172 + 2093/3600.0 = 172.581
Unread 01-15-2008, 08:47 PM
FRC #1218
Team Role: Coach
but i wont know the value to begin with. it will come to me in the form of x*y'z" but the number could be anything
Unread 01-15-2008, 09:48 PM
Gamer930's Avatar
AKA: Justin
Is that going to be given to you as 3 separate variable?? Then you can just insert those variables into the formula. answer = Variable1 + (Variable2/60.0) + (Variable3/3600.0);
If you are given a string in that exact format then you would have to use a "Tokenizer and Tokens" not sure how you would do that in C or EasyC. If you would like how to do it in C++ send me an e-mail and I will send you some sample code.
Converting EasyC Tracking Code into MpLAB Ultima Programming 5 02-08-2007 09:38 PM
Question about default camera data table in easyC pro itsme Programming 1 01-16-2007 01:57 PM
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 01-11-2006 06:12 AM
