Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 14-01-2008, 13:49
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Q&A response - new interpretation of R16
From Q&A answers:
The rule states that the Robot may not have any two points more than 80 inches apart when measured horizontally. The parenthetical phrase is intended as a clarifying example, but it does not convey the same authority as the rule. It is recognized that a small set of configurations exist (with an equilateral triangle with 80 inch sides as the degenerate case) that are in compliance with the letter of the rule, but may violate the example. In all such cases the rule, and not the example, will be enforced.
Close enough to taste it, too far to reach it
Unread 14-01-2008, 13:53
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Re: Q&A response - new interpretation of R16
Originally Posted by Gary Dillard View Post
From Q&A answers:
Yes! No cylinder! (They have effectively declared a square, but your robot must fit in it in every orientation.)
(And Dave--if you read the edit--I did use the word "must" in the original.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 14-01-2008, 14:05
Rookie Year: 1998
Even though I planned for the previous interpretation, I kinda thought they might go this way. It can be verified/enforced with a tape measure rather than an 80 inch diameter fixture. I'm OK with it since the ruling was made early enough in the season (although a week ago would have saved alot of headaches.)
Unread 14-01-2008, 14:47
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
For reasons of irony and superstition, I would like to keep tape measures away from this rule*. Maybe FIRST should construct giant 80" pairs of outside calipers. It would be entertaining to watch the Refs/RIs use them (I certainly want to use one). Then in the offseason, we can bronze them and make them into statues! I'm sure a giant caliper statue would fit right in at Dean's House.
But seriously, I think this affords everyone a little more room to make their mechanisms work and clears up the rule early enough in the season. Good Job!
*For those of you who were not around FIRST in 2002, see one of the many tape measure rule threads
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 14-01-2008, 14:52
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's called a "tram gage", and you can buy them
http://www.chassisliner.com/Product_Measuring_All.shtml
Unread 14-01-2008, 15:03
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Yea! We get a couple more inches to work with, even if bumpers stay included (I talked earlier in ohter threads about not including the bumpers in the 80 inches). I for one am a happy camper.
Re: <R16> Interpretation
EDIT: Wait a minute, no we don't, now I "R" confused. In my head I saw a small window expanding in front of the robot, that is until I drew a picture. It all went away in a hurry. Two vertical poles, 80 inches apart, robot with bumpers on must past between the poles with any and all manipulators going through a full range of motion no matter what the orientation is.
Can we please exclude the bumpers? I know, if we excluded the bumpers then I would still want 83 inches. My head is finally starting to hurt! Thanxs Dave!
Unread 14-01-2008, 15:22
JonA's Avatar
JonA JonA is offline
Embedded Firmware Engineer
no team (Semi-Retired)
JonA has a spectacular aura aboutJonA has a spectacular aura about
The maximum 80-inch dimension interpretation is very different than the you must fit within an 80-inch diameter cylinder interpretation if you have manipulators that articulate or open up to grab the ball. See this PDF.
"That mecanum guy"
- Woodie Flowers Finalist Award Winner: 2010 Minnesota North Star Regional
- Mentor and Founder of 7 FRC Teams since 2003.
- FRC Regional Competition Score Keeper/Field Power Controller, Robot Inspector, Control System Adviser, Judge
- Co-Founder, Alumni: Milwaukee FIRST Support Organization
- Board Member, Game Design Committee, Judge, MVP-FTA: Midwest Vex Programs
- Computer Engineering Alumni '06: MSOE
- Embedded Firmware Engineer: Rockwell Automation
Unread 14-01-2008, 15:23
The Lucas's Avatar
I wasn't going for practicality, I was kidding about building giant Motor Trend Car of the Year style outside calipers. Sort of a Geek Chic thing like MIT's Giant Slide Rule, but enough threadjacking for me. I just couldn't get the image of a team of Robot Inspectors wielding giant calipers out of my head.
Robot Inspector
Unread 15-01-2008, 13:15
MrForbes's Avatar
AKA: Jim
You may have been kidding, but it might be helpful to make your own giant outside calipers, set at 80", from whatever is handy...say an 8 foot long by 4" wide strip of plywood and two shorter strips screwed onto the ends at right angles, with exactly 80" open space between them. Then you can check yourself to see if there is any place around your robot that you can't fit within the 80" limit.
Unread 15-01-2008, 13:26
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I just wanted to point this out: the equilateral triangle isn't really the limiting case for a 3-sided figure. It's actually the curvilinear triangle with a width of 80 in. It has more area, for a given width.
I realized that after about 24 hours of thrashing around thinking about this problem. I'm still trying to figure out how much a difference this makes, and how to shape the robot so as to get the maximum useful area. Thanks, FIRST, for providing sleepless nights even when I don't meet with the team.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 14-01-2008, 14:18
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
Rookie Year: 1998
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Originally Posted by EricH View Post
Yes! No cylinder! (They have effectively declared a square, but your robot must fit in it in any orientation.)
No. They said, "the Robot may not have any two points more than 80 inches apart when measured horizontally." An 80" square will have a horizontal dimension greater than 80" (its diagonal).
Take the rule for what it says. No more, no less.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
No they didn't. Read the Q&A answer again.
The rule is exactly the same as it was when it was written. An 80-inch square would have a diagonal measurement of 113.14 inches, which is a clear violation of the rule.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 14-01-2008, 14:38
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
-dave
Out of curiosity; who's maniacal idea was it to have the 80" rule?
Unread 14-01-2008, 14:39
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Dave, read Eric's post again. He's saying that the bounding box is a square, but your robot must fit in it in ANY orientation. If you can fit such a square regardless of your orientation, then you are within <R16>. If there is some orientation such that you don't fit, then you are violating <R16>. As such, Eric's definition is precisely <R16>.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #15   Spotlight this post!
Unread 14-01-2008, 14:42
Lavapicker's Avatar
Lavapicker Lavapicker is offline
FRC #1056 (Hot Rocks)
Lavapicker is just really niceLavapicker is just really niceLavapicker is just really niceLavapicker is just really nice
I'm still confused....does that mean we can have an arm that reaches out to 80 inches, as measured from the back of the bumber, and still be ok? That's the way I read it and then I see the Cylinder thing which contradicts it. Is there a definitive answer?
Penalty re: <R16> GaryVoshol Rules/Strategy 4 10-01-2008 15:56
R16 Playing Configuration skimoose Rules/Strategy 11 07-01-2008 09:18
Senator Response re:FIRST & the state budget Brandon Martus Announcements 2 03-11-2007 16:45
New Bumper rule interpretation - straight from the lead inspector Gary Dillard Rules/Strategy 17 12-03-2007 14:56
Update 6 Q&A # 132 ... INTERPRETATION PLEASE!!!! archiver 2001 2 24-06-2002 00:26
