Go to Post GP and the Scout Law are high ideals that only the best will achieve and live everyday. - Al Skierkiewicz [more]
Unread 14-01-2008, 13:51
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
FIRST Back-up Battery Charger
Is the FIRST back-up battery charger made to be get power from the fuse panel or straight from the battery.
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 14-01-2008, 14:14
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: FIRST Back-up Battery Charger
You should fuse EVERY power bus coming off the battery. The charge circuit is no exception. It will prevent an overall loss of power if something in that circuit shorts to ground.
To answer your question, technically, it'll work either way. But the smart answer is to determine the max current it will draw, and fuse it.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 15-01-2008, 00:59
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
<R50> pretty well covers it. The only thing connected straight from the battery is the 120A switch/breaker. You will fuse the charger, as it is a load. Any questions, see the 2008 power distribution diagram.
On-Board Battery Charger bronxbomber92 Technical Discussion 6 08-02-2007 11:11
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Battery Charger Circut PyroPhin Electrical 1 30-01-2003 13:49
battery charger archiver 2001 3 23-06-2002 23:20
Battery Charger jgrater Kit & Additional Hardware 1 12-04-2002 14:14
