3ds Max problems
i have made a geosphere and a tube and want to add an omni light and modify it. i have added the omni light and modified the basic parameters, but i need to add the "Atmosphere and Effects" one, specifically the lens effect. whenever i try and "Add," a window pops up and says an error occured, then the program closes. any help you could offer wood b helpful. thanks!!!
Re: 3ds Max problems
i trying to create an outerspace scene, i wanted to use lens effect, glow, string, streak, ray, and ring mostly. thanks!!
why dont you try a sphere with self-illumination turn all the way up and then put a fall off in the opacity map parameters. If you are trying for a sun-glowyish thingy.
Another way to do glows, is to render out a completely white sphere with self-illumination turn all the way up in the place where you want the glow. render the sphere out as separate layer and take that layer in to Combustion and then blur the layer, change the color of the layer and viola! a glowy layer without your computer spending time rendering the glow frame by frame. |
| 3ds max 7 installation problems | sirbleedsalot | 3D Animation and Competition | 1 | 15-05-2005 21:18 |
| 3ds max 6 problems | LBK Rules | 3D Animation and Competition | 3 | 15-01-2005 22:46 |
| Problems with 3DS Max Licensing | jlewellen | 3D Animation and Competition | 10 | 24-11-2004 14:58 |
| 3ds max 6 | Bduggan04 | 3D Animation and Competition | 20 | 03-09-2003 20:37 |
| 3ds max problems.. | cgDynasty00 | 3D Animation and Competition | 9 | 26-03-2003 07:36 |
