Can you apply an assembly extrusion to a part?
Team 74 has made a full assembly of our frame and in this assembly we trimed a peice tube with the "cut" extrusion. This was done in the actual assembly not in the part its self.
So my question is this: Can we then apply this extrusion so that it shows up in our part's drawing? Thanks |
| Can the VEX controller be programmed in assembly? | Capt. Quirk | Programming | 7 | 23-12-2007 09:31 |
| Assembly to Part | Zoheb N | Inventor | 8 | 07-02-2007 01:26 |
| Can we use part of a container on our robot? | Rick | General Forum | 1 | 10-02-2003 20:10 |
| Can I reduce the number of similar part files? | roknjohn | Inventor | 2 | 29-01-2003 21:36 |
| How much can the window assembly lift? | archiver | 2000 | 9 | 23-06-2002 22:59 |
