In the manual, <R16> to be exact, it says that the robot may expand up to a total of 80 inches. Now does that mean that we have 80 inches from the center of the robot, the end of the robot, or do we basically have an 80 inch imaginary bubble around the robot?
Thanks |
Re: 80 inch diameter?
80 inches maximum horizontal dimension - which is probably across your robot on a diagonal.
This is correct, however, if you were to get tipped and your robot was "stretched unlimitedly", you would get called for the 80". It happened last year
Be careful with the 80" rule, the Q&A were updated yesterday:
http://forums.usfirst.org/showthread.php?t=8160 http://forums.usfirst.org/showthread.php?t=8159 With these explainations: Quote:
| 3 inch Mechanums | CraigHickman | Inventor | 1 | 21-09-2006 19:18 |
| [OCCRA]: diameter | mikaela50 | OCCRA Q&A | 1 | 28-09-2005 19:34 |
| Going over 6 inch step with 12 inch wheels | Joe P | Technical Discussion | 25 | 12-04-2004 11:15 |
| Goal Diameter | Bremma | Technical Discussion | 2 | 13-01-2004 06:23 |
| Pipe Diameter | archiver | 2001 | 1 | 23-06-2002 23:45 |
