Go to Post Remember, let function drive design, not the other way around. - Tom Bottiglieri [more]
Unread 14-01-2008, 23:26
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
Team Role: Leadership
Rookie Year: 2007
team2061 will become famous soon enoughteam2061 will become famous soon enough
How to do a Forklift type robot.
My team wants to go with a forklift type robot but doesnt know how to achieve this. can someone please help?
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 14-01-2008, 23:43
Jaybee1405
Posts: n/a
Re: How to do a Forklift type robot.
There's two ways to do it:
1. Continuous (preferred): You line up vertically stacked 8020 in front of each other (we'll say 2 for simplifying the example). A cable runs from the base of the back 8020 to the top of the back 8020 (through a pulley) and then down to the bottom of the front 8020 (another pulley) and is then tied to the top of the front 8020. You put a motor with a winch near the base of the back 8020 (which is bolted to the robot's frame) and when driven, it will lift the front 8020. The front 8020 will slide up and down, and you can mount any type of forks on it. This isn't true "continuous" because you're relying on gravity to pull it back down, so it's much better to have it continuously looped and powered.
2. Cascade: Four 8020 stacked vertically next to each other. Cable starts at bottom of back 8020 on winch with motor. Cable then runs to top of back 8020 (through a pulley), over, and then under second-to-back 8020 (another pulley) and then tied to bottom of second-to-front 8020. Another cable is tied on top of second-to-back 8020, looped under second-to-front 8020, and then tied to bottom of front 8020. Et cetera! The cables become taught and push up the 8020 in front of them.
These are both very simple methods, and I know I made it sound very complicated. If I had pics I would show you, but I don't.
Good luck,
Joe
Unread 14-01-2008, 23:56
Jaybee1405
Posts: n/a
also, see http://www.chiefdelphi.com/forums/sh...ad.php?t=61407
Unread 15-01-2008, 12:03
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
Rookie Year: 2007
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
Good luck,
Joe
You're number 2 idea is what I want to do, but our team leader doesn't want it because he doesn't like the possibility of it binding. Just throwing that out tehre as a possible con.
Unread 15-01-2008, 23:34
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
what are the pros and cons of each of these types?
thanks, Vivek
"we don't build robots, we build people"
Unread 16-01-2008, 00:53
octothorpe's Avatar
octothorpe octothorpe is offline
AKA: Nick Felt
FRC #0766 (MA Bears)
octothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to behold
Here's a picture that someone posted to illustrate the two types:
http://www.chiefdelphi.com/forums/at...achmentid=2834
Somewhere on Chief Delphi there's a powerpoint explaining the advantages and disadvantages of either type. I think Continuous is the most common and pretty clearly the better of the two (it's the version my team is considering). As far as I can tell, Cascade uses more wires, requires the up wire and down wire to move at different speeds, and causes each of the elevator segments to lift sooner (meaning a higher CG and thus more instability at anything less than full extension).
Unread 16-01-2008, 00:57
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
Whatever you do, dont use draw sliders! My team did that last year, and it worked terrible.
Unread 16-01-2008, 01:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
That was Chris H. You can find it here
2001-2004: Team 100
2006-Present: Team 254
Unread 16-01-2008, 09:13
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
You can also use a dual acting pnuematic cylinder to move a forklift up and down. Of course you'll be be limited to the maximum stroke length, so you'll only get fully up or fully down. But since you only have one fixed height to lift the ball over this year, pnuematics may be the way to go. There much simpler and are more robust that using a motor, then you need to worry about things snapping, backdriving, etc. You needed precise control last year because there were three different heights of spider legs, this year it's just one height.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 16-01-2008, 09:45
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Assuming you mean drawer slides, I couldn't disagree more. Last year, my team used heavy-duty ball bearing drawer slides that we got at a local hardware store (you can get similar off of McMaster-Carr; but Home Depot, Lowes, etc. don't carry them) and it worked beautifully. The friction was very low and we never had any binding problems. 217 and 229 used server rack slides in 2005, and that also worked very well (where we got the idea, actually). I think 111 may have used something similar in 2005 as well (their linear bearings look very similar anyway, just much larger). I imagine that if you used bad drawer slides (like those from Home Depot) that they might not work well; however, with some decent slides they work great! If I was building a elevator this year, I would either make it like the how Poofs/RAWC did last year, or with drawer slides. Those 80/20 sliders, while quite usable, IMHO, just don't compare to the smoothness and low-friction of running on ball bearings.
BTW, I would be careful about using pneumatics for big actuations... it may look like there is a lot of air stored on the robot, but a 24" stroke cylinder can blow through it pretty quick. Imagine this: you're in match three of the finals on Einstein, you're trying to stick the ball on the overpass to seal a win and your air runs out . Constantly running the compressor will heavily eat into your battery life, too. Don't get me wrong, I love pneumatics for short, fast actuations (like a gripper or shifter) or even one-time/very infrequent large actuations (like ramps last year or unfolding a mechanism), but I just wouldn't use them when I need a big-bore, long cylinder to do a job that needs to be done many times.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 16-01-2008, 19:12
Mechanical/Driver
Our "forklift hybrid" will run off of pneumatics, with a compressor onboard. I was weary of the air running out too, but we all came to the consensus that pneumatics would drastically simplify the design. Plus the "other part" of our manipulator uses up a good amount of motors that would drive the forklift. With the compressor, and constant replacement of batteries, we should be fine, hopefully.
Unread 16-01-2008, 21:39
cobrawanabe1699's Avatar
cobrawanabe1699 cobrawanabe1699 is offline
That kid with the TIG welder
AKA: Matt, or to those in the northeast, THE BOBCAT!!!
FRC #1699 (ROBOCATS)
Rookie Year: 2007
cobrawanabe1699 is a jewel in the roughcobrawanabe1699 is a jewel in the roughcobrawanabe1699 is a jewel in the rough
Careful with the weight of a forlift. That's alot of aluminum on the front of your bot. See my post in the contact patch thread.
BOBCAT OWNS
I done welded me a robot!
TECHNICAL JUDGE:
FLL Bash @ The Beach 2007 Regional Competition
FLL State Championship, CCSU 2007
FLL Bash @ The Beach 2008 Regional Competition
ATTENDING IN 2009:
FIRST Kickoff in NH
FIRST Regional Competition: Washington DC
FIRST World Championships: Atlanta, Georgia
"If it ain't broke, fix it 'till it is."
Unread 16-01-2008, 21:51
vivek16's Avatar
AKA: vivek
Rookie Year: 2007
"wheelie bar" as seen here: http://www.chiefdelphi.com/forums/sh...threadid=61840
would probably be a good idea to consider...
-vivek
Unread 16-01-2008, 21:53
M4 Sherman's Avatar
Yeah, We used got some heavy duty drawer sliders from Lowes. I think the specs on them were 4 ft. at 50-75 lbs.. All the little plastic pieces broke and the sliders started derailing. But Im sure the McMaster-Carr ones are more durable sliders.
  #15   Spotlight this post!
Unread 16-01-2008, 22:13
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
Team Role: Teacher
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Where is this post??
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Robot Type Betty_Krocker General Forum 0 08-01-2008 22:17
How to type my code jewbilee Programming 7 07-03-2007 21:51
My car-type robot jeffmorris FIRST Tech Challenge 4 18-09-2005 19:30
My power wheelchair-type robot jeffmorris FIRST Tech Challenge 1 17-09-2005 20:56
Field Location of Type-0 and Type-1 IR Signals Travis Hoffman General Forum 3 27-02-2004 07:58
