Go to Post when all else fails, try making the bot go slower - KenWittlief [more]
Unread 15-01-2008, 10:12
kDude kDude is offline
FRC #2450 (RaiderBots)
Team Role: Leadership
Rookie Year: 2007
kDude is an unknown quantity at this point
weight distribution
So we're finalizing our chassis design, and we are going to have 2 powered wheels (6") in front and have 2 omni wheels (6") in the back. But we're not sure where to place our electrical components, battery, gearboxes, etc. Should we have the weight evenly distributed, or have the weight shifted to a certain end?
Another question, our team is going with a fast and small robot and our chassis is 25 1/2" x 35 3/8", but we aren't sure how tall to make construct it. Any insight?
Unread 15-01-2008, 10:18
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: weight distribution
If you're not going to have any ball handling "stuff" on the robot, then you probably want to make it as low as possible (remember you'll need a part that sticks up 51" to mount the flag).
We're trying to get our center of gravity (to use the old term) as low as possible, centered on the robot front/rear, and to the left side of the robot as much as practical.
Unread 15-01-2008, 11:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
If it isn't too much trouble, I'd recommend running chains to those omni wheels so they are powered too. You'll get more pushing force.
Unread 15-01-2008, 11:53
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
If you plan to make fast left turns, you might want to put more weight on the left side of the base of your robot. Especially if you have any sort of arm, forklift, etc that might be carrying a ball. You don't want your CG to get outside of your right wheels when you're turning; if you do, you'll tip over.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 15-01-2008, 15:22
Rookie Year: 2007
Well since our robot has a greater width and length than the height, I don't think it would tip over, right? Which brings me to the possible height of our robot. We're just talking putting the electrical boards, battery, and gearboxes in it, no mechanical arm or pneumatics so it should probably be around 24" tall?
Unread 15-01-2008, 15:34
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Remember the flag rule...but that mast for the holder shouldn't affect the CG too much.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 15-01-2008, 15:47
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
For weight distribution, you'll want your stable center of mass slightly in front of or slightly behind your center of rotation (which looks like it's the exact center of your bot). If it's a low-profile bot, center of gravity doesn't look like it's of too much concern; just put your flag-holding device slightly left of center.
GitHub
Unread 15-01-2008, 16:01
Rookie Year: 2007
What about if the robot had 4 omni wheels, one on each corner, and the two power wheels on the middle of either side. That would give us a much tighter turning radius.
Unread 16-01-2008, 09:07
IbleedPink233's Avatar
IbleedPink233 IbleedPink233 is offline
FRC #0233 (The Pink Team)
IbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to behold
It sure would give you a tighter turn radius, allowing you to spin in place about the center of your robot, ie tank drive. If you did this, then putting the weight in the center of the robot would probaby be your best bet. That way, you won't have weight on the outside to swing around and slow you down (at least, that's what basic physics would say, I don't know about the real world) and you would have more weight on the traction wheels, where it does the most good.
Somehow I don't think that placing weight on the left side would help you make fast left turns in this wheel configuration (if so, then it could slow you down if you need to go around the Track in reverse), but I could be wrong.
Unread 16-01-2008, 09:41
MrForbes's Avatar
AKA: Jim
If you look at the relationship of CG relative to where the wheels contact the floor, and then you look at the forces acting on the robot going around a turn at speed, you might find that locating the CG over towards one side will indeed affect the speed at which you can make a corner bofore the robot falls over. Although if your CG is low enough, then you will loose traction long before this becomes an issue!
24" sounds way way too tall for a robot with no ball handling stuff, I'd shoot for 8" or less overall height, not counting flag holder.
Unread 15-01-2008, 15:01
Rookie Year: 2007
Would that mean putting in two more gearboxes?
Unread 15-01-2008, 15:02
MrForbes's Avatar
AKA: Jim
No necessarily, you can drive the front wheels off a different sprocket on the same transmission that drives the rear wheels. There are lots of different drive arrangements, you might want to spend some more time looking around here at pictures of various robots.
Unread 15-01-2008, 15:06
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Really good pushing force won't be a deciding factor this year, I predict.
Not particularly. Extra tensioners, more chain and maybe a few more sprockets. Double sprockets on one of the normal wheels, one to drive, one to the omni's. I wouldn't suggest it, though.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
more pushing force = better robot driving performance....not necessarily just pushing other robots.
  #15   Spotlight this post!
Unread 16-01-2008, 08:51
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Yeah more torque means more pickup, you'll be able to get to top speed much quicker.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Weight? Estmate weight? Arkorobotics General Forum 21 29-01-2007 17:34
Wait...weight...weight!!!! Greg Perkins General Forum 3 22-02-2006 07:42
weight distribution? chrisw Technical Discussion 3 11-01-2003 13:25
Weight Distribution Mechanism in Tread System? Kai Zhao Technical Discussion 8 20-08-2002 16:38
Weight Distribution Question Eric Reed Technical Discussion 7 19-02-2002 06:08
