Go to Post You know you've been in FIRST way too long when you can remember all those hints... even down to exact wording... and only have to look up the most recent. - EricH [more]
Unread 15-01-2008, 12:26
jjjeski jjjeski is offline
FRC #0223
jjjeski will become famous soon enough
pic: Team 223 Chassis
Unread 15-01-2008, 12:27
CraigHickman
Posts: n/a
Re: pic: Team 223 Chassis
Might as well be the first one to say this...
Have you all though about your CG? From what I'm seeing, that sucker is going to be tip-crazy, especially because of the wide-side drivebase.
Unread 15-01-2008, 12:28
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
We had that problem in 06 w/Alice. was crazy top heavy. could score awesome when we weren't on our backs, but we spent more time over than upright....
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 15-01-2008, 12:30
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
angled frame + back or side heavy + trackball = oh god, this won't end well.
Unless you weigh down the opposite side. Which you might not be able to weigh down enough if you can't make weight normally. If you can, pull a Quixilver and ziptie some rebar to your robot. It seemed to work alright for them...
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 15-01-2008, 12:32
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
This paper
http://www.chiefdelphi.com/media/papers/1974
might help explain the situation...
Unread 15-01-2008, 12:40
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Wow... cut them some slack.
I'm sure a team that's been around that long knows what CG is, and I bet that's only 50-60 pounds of what's going on the robot, you don't know how the rest is distributed. For all you know that could be all 1/16" wall and be much lighter than you are guessing.
114 of all people should know that being tall doesn't necessarily mean poor CG.
Unread 15-01-2008, 12:45
Otaku's Avatar
AKA: Michael Baker
Tall doesn't mean high CG, no.
However, tall & offcenter does mean unfavorable CG, typically.
Lets say that there is 60lbs there. Add in the chassis weight, lets say 15lbs, evenly distributed, and the rest of the 120lbs (putting 45lbs) on the other side. Divide that 15lbs for chassis by two and you get 67.5 (woo hoo) lbs on one side and 52.5lbs on the other side. Add in the height, and it gets pretty bad. Then add in the dimensions and it multiplies the problem.
And that's in the best-case, from what I can see.
Unread 15-01-2008, 12:50
AdamHeard's Avatar
Lead Mentor
I stand by my original statements. I highly doubt that 45 pounds is in that structure.
Considering that 1" square 1/16" wall is only .28 pounds per foot, I highly doubt there is any more than 10 pounds (and that's overestimating) in that structure.
As for it being off center, we have no idea what the rest of the robot is. It could have an arm that extends the other way and brings the CG perfectly in to balance.
And yes, not all old teams are capable, but a team capable of putting together a CAD that nice looking is most likely capable of setting material properties/weight and then going to view> Center of Gravity.
but then again, it's possible they used entirely heavy materials on the top while discovering some new amazingly light material to use on the base.
Until we get the details from 223, let's hold off on the immediate criticism shall we?
Unread 15-01-2008, 12:54
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
/they better dont fall...i've picked them twice in the Fantasy First
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 15-01-2008, 12:55
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Is that by chance 80/20 QuickFrame I see?
Unread 15-01-2008, 13:02
MrForbes's Avatar
AKA: Jim
Sure, I'll hold off on the criticism, and only stress the constructive.....
Last year we used a single 3" diameter, 1/16" thick round aluminum tube as a mast to support our arm. It worked very well, and allowed us to make a heavy drive base and a virtually untippable robot. Attatching the arm mechanism to the tube was fairly easy, once we figured out that we could make sheet aluminum brackets, and clamp them to the tube.
Making a drive base with the wheels going the long way results in a contact pattern of the wheels on the carpet that is about two feet square.
A pair of arms that are spaced about 26" apart will contact the ball about 4" off the floor. If they are activated as soon as the ball is fully on them, they might be able to lift the ball without the ball bouncing out first.
An amazingly light material is really nice for the upper part of the robot. An amazingly heavy material is really nice for the lower part of the robot.
Wheelie bars are not necessarily part of the chassis, they may be part of a mechanism.
Unread 15-01-2008, 13:09
FRC #0223
Just so you know, 223 is Xtreme Heat. 233 is the Pink Team.
We are team 223.
Unread 15-01-2008, 14:42
FRC #0223
Also, the chassis is not complete in the picture. We're still working on it now.
Unread 15-01-2008, 15:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Why is the chassis cut on an angle at the ends? There are no obstacles to clear and I'd think you wouldn't want to be riding up over other robots.
  #15   Spotlight this post!
Unread 17-02-2010, 23:51
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
i dont think that cg would affect them in a normal game, going over the hump..... that changes things a lot.
pic: Team 1058 chassis PVCMike Extra Discussion 3 30-01-2007 22:28
pic: Team 1058 chassis II PVCMike Extra Discussion 10 29-01-2007 23:53
Hats off to team 223 M. Hicken Thanks and/or Congrats 1 08-03-2004 17:42
pic: Team 27 2004 Chassis CD47-Bot Robot Showcase 2 25-02-2004 23:29
pic: Team 369 Chassis CD47-Bot Robot Showcase 7 11-02-2004 19:58
