Go to Post Just be yourself, be honest, and most importantly, be present. The best role models are the ones you can relate to. - Jessica Boucher [more]
  #31   Spotlight this post!
Unread 16-01-2008, 12:04
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Team Update #3
Originally Posted by jgannon View Post
I have to disagree with you on this one, Eric, if I'm understanding 1075guy's post correctly. There is no rule to say that the robot can't start acting at the beginning of the match without a signal from the Robocoach (obviously, since this would disallow full autonomy). If the Robocoach pushes a button, then it will do something different. It will do the same thing every time you push that button, regardless of when you push it. This satisfies the requirements as I understand them. As such, in some sense you can think of this as five actions: a default, and a response to each button. I suspect that many teams will have "do nothing" as their default action, but I also imagine that there will be a number of teams who will start moving at the beginning of the match before the Robocoach presses a button, and they will do so legally.
Now that I look again, you're right. Gary (below) would also be right.
For example, if your default was "drive straight" and every button had a "after x action, default" (or just "drive straight"), I would say that is legal.
What I thought he said was "I do nothing for x seconds and have that as a command." That is having more than one command, unless you have a default.
Maybe any team using a default should put the default action at the top of their card with a note that "the robot will do this unless I tell it to do otherwise."
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #32   Spotlight this post!
Unread 16-01-2008, 12:10
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Re: Team Update #3
From the following page:
http://www.usfirst.org/community/frc...nt.aspx?id=482
Briweld Industries - Practice Driver station kits
is not a valid link.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
  #33   Spotlight this post!
Unread 16-01-2008, 13:27
Mr MOE's Avatar Woodie Flowers Award
Mr MOE Mr MOE is offline
MOE 365 Team Coordinator
AKA: John Larock
None #0365 (Miracle Workerz)
Rookie Year: 2000
Mr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond repute
Re: Team Update #3
GDC - thanks for the clarification.
When I read the fourth paragraph of Team Update #3, I could almost hear it being read by the folks in Monty Python and the Holy Grail.
"The number of commands shall be FOUR. The associated number of actions shall be FOUR. FIVE is RIGHT OUT!"
Thus speaks the GDC on the usage of the Holy RoboRemote.
MOE Celebrates 18 Years in FIRST this season!
2007 CMP Chairmans Award - thanks to all MOEboteers, past and present!
Team Update #2 Thexder General Forum 26 01-02-2008 12:56
Team Update #21 Mark McLeod General Forum 3 19-04-2007 09:42
Team Update #18 Ben Piecuch General Forum 114 23-03-2007 17:52
Team update #12 Rob Colatutto General Forum 7 20-02-2004 16:13
Team Update #7 Up Steven Carmain General Forum 5 27-01-2003 23:15
