Go to Post i swear, if it were april fools day, i would not believe this whole lord dumpling/dean kamen thing...but then again, this is FIRST - sure_smile [more]
Unread 15-01-2008, 20:10
d235j d235j is offline
FRC #4454
d235j has a spectacular aura aboutd235j has a spectacular aura about
Calibration of pressure relief valve
This may sound silly, but I'm afraid I accidentally messed up the calibration of the pressure relief valve. How should I go about to test it and re-calibrate it if necessary?
Thanks.
Unread 15-01-2008, 21:34
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
Re: Calibration of pressure relief valve
<R95> Get a new one. period. No other actions are permitted.
Unread 16-01-2008, 14:01
FRC #4454
Where? I checked Norgren's web page, and the valves they sell (exact part number) aren't pre-calibrated either. It is ok to get a local calibration lab to calibrate it to 120 psi?
Unread 16-01-2008, 14:12
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
last year ours came in the kit "loose", so we had to adjust it, which is against the rules....but you can do it very easily, although you have to assume the pressure gage is accurate. Loosen the lock nut, turn the adjusting screw as needed, tighten the locknut. see if it works by watching the tank pressure gage, if it goes over the rated pressure of the relief valve, then you need to adjust it more.
Apparently this is all against the rules, so don't do this. Get ahold of FIRST and get a replacement.
(ain't politics fun?)
Norgen Relief Valve enpurx Pneumatics 9 07-02-2008 22:32
where do i place the norgen relief valve? Reaper40 Pneumatics 1 25-01-2007 18:25
Where do we get a relief valve? P1d40n3 Pneumatics 4 17-01-2007 10:04
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
Dump valve and pressure gage's tareyton Pneumatics 3 06-02-2003 21:13
