autocad chassis
Does anyone know where I can find the chassis parts in the KOP for autocad?
Re: autocad chassis
Re: autocad chassis
Yeah I checked there and found only extrusion parts for testing. Not the actual chassis.
Re: autocad chassis
what specific parts are you looking for?
Re: autocad chassis
The metal frame with the corner pieces.
Re: autocad chassis
It's technical name is the Kit Bot chassis, and is supplied by IFI.
While it doesn't look like there are CAD files you can just Download on the page on IFI's website, there are prints of all the parts included so you can draw them if needed. http://www.ifirobotics.com/kitbot.shtml edit: See below. That should help you. They ARE on FIRST CAD Library after all. Last edited by Elgin Clock : 16-01-2008 at 00:07. |
Re: autocad chassis
http://www.firstcadlibrary.com/
Left hand side click mechanical Half way down the page there is KoP endcap Also there is KitBot side rail, some KoP angle and come bumper frame stuff Hope this helps |
Re: autocad chassis
You should be able to get 200+ pre-modeled parts here:
http://firstbasefrc.autodesk.com/?nd=m_kitofparts You will end up pulling nine zips of parts in various categories. |
| Mechanical Desktop 2004 DX/AutoCAD 2004 and AutoCAD 2005 | coastertux | Inventor | 4 | 14-06-2005 09:27 |
| AutoCAD prints? | indieFan | Inventor | 2 | 29-11-2004 08:00 |
| Redimensioning in AutoCAD | indieFan | Inventor | 5 | 08-01-2004 16:55 |
| AutoCAD Viewer | Gadget470 | OCCRA | 2 | 25-09-2002 03:19 |
| AutoCAD 2002 | David Kelly | Inventor | 7 | 24-06-2001 09:11 |
