Go to Post So I usually end up looking pensive or confused. :) - Karthik [more]
Unread 16-01-2008, 00:22
Mikhail_Pham Mikhail_Pham is offline
Mikhail_Pham is an unknown quantity at this point
Belts vs. Chains
We're from a rookie team in Irvine (TUSD) California, and while working, we came across the issue of whether to attach a chain or a belt to the sprocket. We figured the belt was lighter and more efficient, but, looking around, a lot of teams seem to prefer chain.
Why? I understand that older teams may like the dependability and long lasting quality of a good metal chain, but other than that, why?
Unread 16-01-2008, 00:32
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Re: Belts vs. Chains
Chains (if & when) they break, are easier to fix than belts in most cases.
Here's my logic behind that from using chains for a number of years now.
If you break a chain, just add some more pieces to it very simply.
In a belt system, you (more than likely) need to access the entire run of it, and replace the full belt.
I don't know why other than that, but I just know they are easier to replace than a full belt when dealing in confined spaces of the footprint we personally (as a team) use to run our chain.
Don't get me wrong, a break in the system is still a pain in the butt to fix no matter if it's made out of chain or anything else for that matter, but it's easier to get to one part of it than to get to the entire running path most times (in our designs anyways).
Your results may vary.
/my 2 cents.
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 16-01-2008, 07:39
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
FRC #2175 (The Fighting Calculators)
Rookie Year: 2007
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
Belts can also slip. We learned that the hard way when trying to left two robots. A chain hopefully wont slip as easily.
Unread 16-01-2008, 08:05
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
We have been using timing belts from McMaster-Carr in our drivetrain for years and have never had a failure, check the specs., they keep getting stronger and stronger ratings. We have used slots for tensioning (transmission/CIMS slide back and fourth). Belts do require more work to replace, we just have never had to. We have a four wheel drive 06' (kit tranny w/ two cims each driving 8' wheels) with four belts that are still original with no sign of wear. On short runs I would recommend timing belts, longer runs are probably better served by chains.
Unread 16-01-2008, 08:43
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Belts:
Quiet, Light, Smoother, more flexible
Weaker, can slip, crack, break, strip
Chain:
Strong, robust, more efficient
Heavy, abrasive, can pop off, stretch
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 16-01-2008, 11:23
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Has anyone actually broken a chain on a drive system before? I've never heard of something like this and would think it'd be very difficult to do on a FIRST robot, even if you're only using #25 chain.
Is there anything special to watch out for or particular situations to avoid when designing a chain system to prevent the chain from breaking? What kind of situation in a match would cause this?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 16-01-2008, 11:49
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
#25 can break
I am not sure of other team's frequency with such an event, but I have seen in personally twice.
That is over 5 robots and lots of chain chain though.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 16-01-2008, 11:54
Courtneyb1023's Avatar
Courtneyb1023 Courtneyb1023 is offline
AKA: Courtney
Courtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to behold
It might be nice if this were a poll.
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Think about the load on the chain when the robot is pushing and the weight is mostly all on the rear wheels....about 70 lbs per wheel, times the wheel to sprocket diameter ratio, is pulling on each chain. Design working load for #25 chain is generally a bit over 100 lbs, so it is possible that the chain can break.
Unread 16-01-2008, 11:57
Yep... It happens when you replace a screw very quickly between matches in the path of your chain with a head that is too big (re: socket head cap screw as opposed to a nice button head, or better yet, a countersunk screw).
Those protruding heads tend to put stress on not only the chain itself, but the retaining clips and "break" your chain when it is very much unwanted... (re: in the middle of a match. )
Leasson learned: Use countersunk screws in the path of a chain, and have plenty of extra's around in case you need more.
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
YES, #25 can break and will, especially on a drive train. We have an absolute rule that no #25 on the drive.
We do use it in some other lower stress / lower power areas.
There is a good write up of chain vs. belt on the gates website -
http://www.gates.com
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 16-01-2008, 12:23
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Same here. In 2001, we had #25 in the drive. During 2003, when it was our practice robot, we spent more time replacing chain than we did driving.
We used some in our shooter in 2006 (intermediate pulley system to the shooter wheel). The rest of the power transmission there was a belt, and we never had a problem. Actually, most of our shooter/loader was belting, either for transport (timing belt driven by an FP) or for shooting (Big CIM to intermediate axle, where we put chain the rest of the way).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-01-2008, 13:56
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
On the contrary to the above posts...
I have personally used #25 chain on 3 robots. 1 of which did ALL of the gear reduction through chain and sprocket (yep thats right 12 chains per side) and I have never had a chain break.
A lot of people tend to think that #25 chain is weak and will not work. Our team looked extensively at the numbers of #25 vs #35. The result was us using #25 chain on our robot (and not a chain broke).
Tension. Tension. Tension. Keeping those chains tight is the miracle cure of chain breakage.
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 16-01-2008, 14:47
aztech75 aztech75 is offline
FRC #0157 (aztechs)
aztech75 has a spectacular aura aboutaztech75 has a spectacular aura about
Send a message via AIM to aztech75
Before we started to use belts, we were breaking chains left and right. In the four seasons that we used belts we broke one at battlecry and thats it. If you get the belts with teeth, and pulleys that are designed to fit those specific belts, than they will never slip.
  #15   Spotlight this post!
Unread 16-01-2008, 14:50
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
The last time we used #25 was on our shooter in 2006. It was pretty tight; we did use a belt for most of the motor-wheel connection and chain was only on the last six inches or so.
I would say run the numbers and go with the easiest and lightest solution that will work (in that order, probably, except work comes first).
Past teams:
chains on inventor naroarr Inventor 9 27-02-2007 15:55
VEX Chains chewy VEX 13 21-11-2006 14:14
chains sburro Technical Discussion 13 07-10-2004 11:37
chains enjoiwheels Inventor 0 08-02-2003 19:33
Belts, Timing Belts, and Automobiles. Anton Abaya Technical Discussion 5 09-01-2002 19:21
