Go to Post As to "no fasteners," I have a gallon of epoxy, and I'm not afraid to spread it. - Rick TYler [more]
Unread 16-01-2008, 00:50
HansZhou HansZhou is offline
FRC #0694
HansZhou is an unknown quantity at this point
Quick Question
Well, something which I noticed while working with a pneumatics setup today was that the compressor was liable to heat up very quickly, mostly because we had a leaky setup which required repeated compressing. However, if the pneumatics tubing was to be incorporated with the rest of the robot's wiring, with components which are likely to generate a lot of heat, I was wondering if it is possible, since pV=nRT, to jack up the temperature of an actuator's surroundings to artificially enhance its pressure. This would help a lot since we are designing a pneumatics pusher which would be able to hurdle the ball, which is quite hard to do at 60 psi (in accordance to <R98>). If we either accidentally or intentionally (for a small actuator, the difference is quite noticeable) increased this pressure by increasing the temperature, would this be acceptable if we did it by accident or practical if we did this on purpose.
Unread 16-01-2008, 01:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Quick Question
You might find that the regulator will do a good job of keeping the pressure at 60 psi.
We are hoping to be able to drop the pressure in the catapult system to less than 60 psi with a second regulator
Unread 16-01-2008, 01:13
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Rookie Year: 2007
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Re: Quick Question
Ah yes. Squirrel brings up a good point, we are required to use a relieving regulator. So not only would this probably be illegal (and "accidently" placing the cylinder near a stalled CIM would be both very unwise and un-GP), it simply wouldn't work.
Originally Posted by 2008 Pneumatics Manual
Norgren has donated the primary pressure regulator. These are relieving regulators. Assume that you extend the cylinder or the apparatus the cylinder is attached to against a wall. Then push against the wall with your robot. That would increase the pressure in the cylinder. The increased pressure will relieve out of the regulator and the cylinder will slowly retract. This regulator has a maximum output pressure of 60psi. This regulator must be placed in-line right after the tanks to limit the pressure to all working circuits to 60psi.
Also, just to cite an actual rule, any extraneous lengths of tubing required to "accidently" route pnumatic lines near heat generating components would probably run afowl of <R01>:
Originally Posted by <R01>
Extraneous lengths of pneumatic tubing shall not be used to increase the storage capacity of the air storage system.
Unread 16-01-2008, 12:11
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Quick Question
I think the heat rise you are talking about would have little impact on the system. The motors and other equipment does not get that hot (or they would burn up), and the tube is fairly thick walled for the level of air flowing thru.
And, it is not a good design practice to place something like plastic tubing near heat sources - it can melt and / or burst.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Quick Question Chief Pride Programming 5 29-10-2007 06:12
Quick Question 3 Minitruck1506 Chit-Chat 0 22-02-2006 16:21
Quick Question 2 Minitruck1506 Chit-Chat 0 22-02-2006 16:17
Quick Question Burgabot Programming 31 02-12-2003 19:22
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
