Go to Post Yup. Two world champs on one alliance, out in the quarterfinals. Only at IRI. - Norman J [more]
Unread 16-01-2008, 07:51
team550 team550 is offline
FRC #0550
team550 is an unknown quantity at this point
IR HELP
according to the specs i saw the digital input on the robot interface is grnd signal and +5 signal floats high so it is at 5 volts if the IR board outputs 5 volts there is no change so the board would not recieve a signal do we need to build an inverter or am i mistaken in my thinking??
Unread 16-01-2008, 09:31
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Rookie Year: 1997
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: IR HELP
NO. The unit is ready to go as is.
You are correct, the signal input pin on the digital inputs are pulled high internally when nothing is connected.
The IR Board applies a Low (ground) to the digital input pin when it is connected but inactive and pulses high when it receives the "learned" signal.
Steve
Unread 16-01-2008, 11:05
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: IR HELP
this brings up an important point about error detection. a good programmer will be able to provide an error indication.
at no time should all 4 decoder lines be high. one line will pulse high for 100 ms, which is long enough to be detected during 3 RC-cycles. if any line stays high for more than 5 cycles in a row, it is likely that the wire is disconnected between RC and decoder. the line will float high when the wire is broken.
as your software reads the decoder bits, only one bit should be active at a time. it might be a good idea to light an error light on the OI console to alert the wiring crew to the problem if more than one decoder bit goes high at the same time.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Cool Re: CD 47 IR Board w/pictures
I have attached a picture of the Chief Delphi IR board w/modifications.
The board has been modified to include a 2 pin power connector with
reverse battery power protection (1N4007 diode, in line with +12V
power), 4 PWM wire outputs (pins 5,6,7,8) of 10 pin connector have
been wired to the top pin of the three wire pwm headers. Hopefully, this
will provide some help to rookie teams trying to figure out how to
wire the IR board to their robot. A special FIRST thanks to Frank Leritz,
Sr. Engineering Associate, of the Hybrid Powertrain labs at the HDC
in Troy, Michigan for making the changes.
Two of the the four pwm cables are shown. One is VEX compatible,
the other IFI controller compatible.
CD moderator. Still trying to figure out this website posting stuff.
Please move to new Thread, thanks.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Last edited by marccenter : 16-01-2008 at 15:56. Reason: updated information to include Frank Leritz recognition
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
