Go to Post A 823543:1 reduction should be fine if you ever need to pick up a truck...or a house. - Tim Sharp [more]
Unread 16-01-2008, 11:39
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Rookie Year: 2007
Japper has a spectacular aura aboutJapper has a spectacular aura about
IR control question
To avoid all of the hassles of dealing with robot placement and line of sight of the IR while in Hybrid mode, is it possible to create an IR receiver that plugs into the OI (under its own power) so that the robo-coach can just send the IR commands to the OI instead of an IR receiver mounted on the robot and connected to the RC or are the ports on the OI totally locked out during autonomous mode???
Just a thought...
custom control programming question... herocreator Programming 4 03-07-2007 12:54
Max Control Board Size Question Dermot_135 Control System 5 07-02-2006 22:12
PID control loop/Encoder question Zee Programming 18 30-01-2004 23:14
PBASIC/control system question archiver 2001 1 24-06-2002 00:33
Control Station Fabrication Question... Jim Meyer OCCRA 1 25-09-2001 05:15
