Did anyone get Values from the GTS? and how did you do that?
Re: Did anyone get a Value from the GTS?
I assume "GTS" means Gear Tooth Sensor?
I haven't tried, but now that we know what GTS means, maybe someone will give a report. |
If you wired it according to the Sensor Manual (http://www.usfirst.org/uploadedFiles...sor_Manual.pdf)
In the sensor Manual it gave you a link to the data sheet on how to mount it. If you are using EasyC for programming there is a sample code for the GTS in your MyDocuments/Intelitek/easyC Pro/FRC/Projects/Test Code/GearToothTest folder. |
| What did you get out of the 2006 season? | Billfred | Chit-Chat | 14 | 31-05-2006 16:22 |
| did you get experience from programming on a calculator? | gondorf | Chit-Chat | 18 | 24-01-2006 21:22 |
| Where did first get the Edu Batteries | hedgehogger | General Forum | 7 | 28-02-2004 01:09 |
| Did anybody get the GMA video to play | archiver | 2001 | 1 | 24-06-2002 02:43 |
| Did anyone see the Today Show? | archiver | 2001 | 1 | 23-06-2002 22:43 |
