Go to Post If I'm going to mentor someone, I'm going to be involved in their life as a positive force. - Mechvet [more]
Unread 16-01-2008, 16:47
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
AndyMark CIM Planetary Gearbox Torque Specs Needed
Hey,
I've emailed Andy Baker twice over the past two days hoping for an answer, but he has yet to get back to me. However, we REALLY need to find specs on the torque output and capabilities of the CIM Planetary Gearbox. We want to use it for lifting out arm because of it's reduction, but we do not know if it will have enough output torque. Any information would be great.
We are about 90-95% CADing our robot and probably 45-55% done machining and 80-85% of our parts we need have been ordered. We hope to have it working within the next 7-10 days. But we need this info to tie up the loose ends.
Thanks.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 16-01-2008, 16:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: AndyMark CIM Planetary Gearbox Torque Specs Needed
It would depend on the torque of the motor? Basically motor torque x 181.
Our arm last year used this box and it lifted the front of the robot off the ground before we programed the stop point.
Unread 16-01-2008, 16:58
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Also factor in .85-.9 efficieny for each of the 4 stages.
Unread 17-01-2008, 18:44
DGrohnke1023's Avatar
DGrohnke1023 DGrohnke1023 is offline
Is Looking Backward to Look Forward
AKA: The Dan
Team Role: Driver
DGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of lightDGrohnke1023 is a glorious beacon of light
I believe Kyle's question is being misinterpreted.
We are curious about if the gearbox can handle the amount of torque the motor can send through it.
So, does any one know if the output shaft is rated to take the
motor torque x 181.
Thanks!
Daniel Grohnke
2009 Bedford Express Captain
2009 - Lansing and Troy Districts, The Championship
2008 - GLR Quarterfinalist & MARC Semifinalist
2007 - GLR & Boilermaker Finalist & MARC Champion
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarterfinalist
2004 - GLR/DTR Semifinalist
2003 - GLR Quarterfinalist & GLR/NAT'L Rookie All Star
Unread 17-01-2008, 18:53
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
motor torque x 181.
Thanks!
It wouldn't be a very good gearbox if it couldn't....
but seriously, if you factor in the losses at each stage due to gears the gearbox is probably in the 60-70% efficiency range (overall) which means that the gearbox would have a stall torque of approximately 261.18 N/m or 192.63 ft/lbs (depending on the actual efficiency)
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Andymark Planetary Alex.Norton Technical Discussion 3 06-07-2007 11:12
Planetary Gearbox Possibility? ThatIndianKid89 Technical Discussion 4 04-02-2007 17:18
Torque vs. Current in small CIM motors robotguru1717 Electrical 2 08-01-2007 17:09
Low Cost Planetary Gearbox Source... Joe Johnson Motors 32 14-11-2006 18:02
pic: Reworked AndyMark Gearbox Mark Jones Robot Showcase 17 07-12-2005 22:53
