Go to Post Everyone is wrong! - Chris is me [more]
Unread 16-01-2008, 17:42
LordKronus's Avatar
LordKronus LordKronus is offline
None #0104
LordKronus is an unknown quantity at this point
Need number help buddies
How much force can be produced by one 3/4 inch piston and how fast does it go in meters per second. Would really appreciate the help.
Unread 16-01-2008, 17:54
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
Team Role: Mechanical
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
Re: Need number help buddies
First of all, how much PSI are you running to it? I'm assuming 60psi, so I'll calculate it as such.
60*.75*3.14 = 141.372
You will produce approximately 141.372 Newtons of force. Using some kinematics equations, you can find the speed.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 16-01-2008, 18:00
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Uh, it looks to me like you multiplied pressure in pounds per square inch by piston circumference in inches, and reported the result as force in Newtons. It doesn't work that way.
The correct calculation is 60 lbf/in^2 x pi()*(0.75^2)/4 in^2 = 26.5 lbf.
That force could also be expressed as 118 Newtons.
Richard Wallace
since 2003
Unread 16-01-2008, 18:04
AdamC's Avatar
Lathemeister
AKA: Batman
My mistake. Thanks for the correction, Richard.
Unread 16-01-2008, 18:14
RANDOMINATOR RANDOMINATOR is offline
AKA: Brian
FRC #0104 (Team Universal)
RANDOMINATOR is an unknown quantity at this point
Send a message via AIM to RANDOMINATOR
OK, well wouldn't another important question be:
Over how much time does this piston extend, as that is the main factor in how useful this force is.
Unread 16-01-2008, 18:39
LordKronus's Avatar
None #0104
wow you guys are prompt and very helpful. the piston to my knowledge extends in about 1/4 -1/2 second, but the force was my really needed information , so thank you all so much.
Unread 16-01-2008, 18:41
LordKronus's Avatar
None #0104
does anyone know what the force needed to fire the ball over or at least the equation to find it.
Unread 16-01-2008, 18:49
AdamC's Avatar
Lathemeister
AKA: Batman
Our last prototype, which was pretty crude and not very efficient, used 135 ft-lbs. to launch the ball 8" vertically. We invested in a 250 ft-lbs. gas spring and are creating a complex lever system to add some extra oomph, but I wouldn't invest much time in attempting to use pneumatics to fire a ball.
Unread 16-01-2008, 19:06
LordKronus's Avatar
None #0104
What if you fire off 3 3/4 inch pistons to break the balls needed initial velocity then 1/2 second later fire off 5 more with longer shafts. at 26.5 ftlbs each it should work and the increase shaft size will direct it and add a kick. now does this work math wise or am i mistaken.
Unread 16-01-2008, 23:27
sethw sethw is offline
FRC #0639
sethw is an unknown quantity at this point
The exact speed at which a cylinder fires will depend on the stroke length, inner diameter of the tubing, which solenoids you're using, and your accumulator configuration. Generally speaking, however, cylinders fired without flow controls will extend in well under a second.
If you have a mechanism to guide the ball at the fire point, this technique could work. With four tanks you'll have plenty of air to fire it, and it seems to check out mathematically. You'll need to make sure that each set of cylinders is firing perfectly in sync so they all contact the ball at the same time. I would recommend doing lots of testing with that design.
-Seth
Unread 23-01-2008, 15:52
andyohyeah andyohyeah is offline
andyohyeah is an unknown quantity at this point
Ok, i'm the head of pneumatics for my first year team, what is the best configuration for a single piston at a 45 degree angle? can you please explain how everything work together?
Unread 23-01-2008, 16:11
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Then you run out of air .
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Do I need to include the team number in my code? theDarkestOne Programming 3 19-02-2007 13:19
HELP: Need the FIRST Online Store Email / Phone Number mtaman02 General Forum 1 23-05-2004 03:50
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
Any programming buddies? Anton Abaya Chit-Chat 6 10-02-2002 22:14
