Go to Post Multitasking is a myth. - DonRotolo [more]
Unread 17-01-2008, 10:01
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Logitech NASCAR Racing Wheel Compatible with USB Chicklet
Has anyone use this wheel (Logitech NASCAR Racing Wheel) on there robot, I need to know if it has another power supply other than the 5 volt USB? If so is the power supply only used for the force feed back?
Thank You!
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Using the USB Chicklet with a steering wheel PhilBot Control System 16 13-01-2008 11:43
Comments on the Logitech steering wheel with pedals waialua359 Control System 7 14-12-2007 16:08
USB Chicklet SleeveofWizard Control System 11 28-01-2007 22:45
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
Does EasyC Pro work with the USB-Chicklet? lightning_blast Programming 6 20-01-2007 23:39
