Go to Post Don't worry about where you will be. Just consider youself lucky for being where you have been. - sanddrag [more]
Unread 17-01-2008, 18:54
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Quick Gyro Questions
In terms of wiring a gyro...
G is Ground on an Analog Input
5 is the +5V on an Analog Input
T is the Signal on an Analog Input
Correct?
And the Gyro received in this year's kit is the AD22304, correct?
Thanks.
Code:
void function(void)
  function();
Unread 17-01-2008, 22:13
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
Team Role: Leadership
Rookie Year: 2007
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Quick Gyro Questions
in the KOP gyro thi year, above the holes there are letters. just plug the male end of a pwm cable into the appropriate holed (by colour and the writing on the board)
Unread 17-01-2008, 22:40
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Rookie Year: 1999
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Jake
You are correct.
tseres:
They will be too loose and give you inaccurate results by simply plugging them in. You will need to solder the connections.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 17-01-2008, 23:15
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
We prototyped the Gyro tonight and had some success with it.
Definitely solder the connections to the Gyro board, and mount the gyro to a hefty piece of metal so that it is parallel to the horizontal plane.
We used Kevin Watson's 2006 default gyro code to test it. The readings in tenths of a degree were pretty accurate when rotating the device.
The gyro velocity angle is still a little confusing to us. I'm not sure it provides useful information.
Keep in mind that all readings are based on the intitial gyro bias calculation at startup. If the gyro is abruptly disturbed after this calculation, all readings may be corrupted and will be suspect.
Temperature can also introduce drift in the readings.
We have more work to be done. However , it will probably only be used for Hybrid-mode anyway.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 24-01-2008, 22:28
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
Rookie Year: 2007
captainking is an unknown quantity at this point
I have a question, there are two slots for plugging in pwm cables into the gyro but the easyc code has it set for 1 analog slot, so do I use a y-cable to plug both in, do I create a new gyro block for the second one, or do I only use one of the slots (if so is it G5T or G5R)
Unread 24-01-2008, 22:36
void* Jake;
FRC #1178 (DURT)
The set of pins with the signal pin labeled T is the gyro signal, which changes based on the rotation of the gyro chip. The other set of pins is a built in temperature sensor, since the gyro signal output changes based on the temperature. Under FRC conditions, you won't really need to use it.
Code:
void function(void)
  function();
Quick Questions Minitruck1506 Chit-Chat 1 21-02-2006 22:08
Two quick questions... mechanicalbrain Electrical 15 08-10-2005 09:23
Gyro Questions Jeff G Control System 8 03-12-2004 19:15
quick questions.... archiver 2001 1 23-06-2002 22:43
Quick Questions E. The Kidd General Forum 14 31-12-2001 23:29
