Go to Post In fact, our robot YOLOs so hard it does drive-bys on the refs. - TrevorKN [more]
Unread 01-17-2008, 08:25 PM
drewjones13's Avatar
drewjones13 drewjones13 is offline
drewjones13 is an unknown quantity at this point
Exclamation HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!!
we are having issues with our IR coding in hybrid mode, below is what we have set up, for some reason its only running the first subroutine as if rc_dig_in10 is already initialized to "on" at the start of the code.
Auton Code:
Code:
time1 = time1 + 1;
if (time1 <= 5)
	rc_dig_in10 = rc_dig_in11 = rc_dig_in12 = rc_dig_in13 = 0;
	pwm01 = pwm02 = 127;
else if (rc_dig_in10 = 1)
	cmd0();
else if (rc_dig_in11 = 1)
	cmd1();
else if (rc_dig_in12 = 1)
	cmd2();
else if (rc_dig_in13 = 1)
	cmd3();
else
Subroutines:
Code:
unsigned char cmd0()
	pwm01 = 190;
	pwm02 = 190;
	return 0;
unsigned char cmd1()
	pwm01 = 64;
	pwm02 = 64;
	return 0;
unsigned char cmd2()
	pwm01 = 190;
	pwm02 = 64;
	return 0;
unsigned char cmd3()
	pwm01 = 64;
	pwm02 = 190;
	return 0;
Unread 01-17-2008, 08:52 PM
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
Rookie Year: 2007
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!!
I believe the if statements are your problem. You're only using one equals sign. That will actually assign the bit the '1' rather than checking equivalence. You need to use the == operator instead.
Out with the match list printouts, in with... Pat Fairbank General Forum 19 02-07-2005 08:15 PM
need help with the ir tinderfitles Programming 3 02-03-2004 03:31 PM
Help with the balls! tchescow Kit & Additional Hardware 11 01-20-2004 10:52 AM
Help with the storyboard. LizJJury 3D Animation and Competition 11 01-13-2003 08:37 AM
Help with the gyro chip Team852 Electrical 1 01-10-2003 10:31 PM
