Go to Post Coming up next on Pimp My Ride.....Yo man, here is the real deal. A two-oh-oh-six Segway I-one-eighty, with stock rims, stock fenders, and two 3 horse motors that red-line at twelve point five miles per hour. Get ready, because I'm going pimp this ride! - artdutra04 [more]
Unread 17-01-2008, 20:39
Semicolon's Avatar
Semicolon Semicolon is offline
Semicolon will become famous soon enough
Gear Tooth Sensor Question
Hey there! We want to test the gear tooth sensor, but manufacturing is still messing with the gears. Can we just wave a steel washer back and forth in front of the magnet sensor? It didn't seem to work when I did it.
In other words, can we test the gear tooth sensor without a gear?
Also... we are having problems. We have downloaded the gyro code from kevin's website, and the gyroscope works just fine provided you twist it really fast. We are trying to combine the encoder code with the gyro code, but there is a lot more to it than just moving the .c and .h files. What should I do?
Stay with me here...
Everyone knows that Time = Money and Knowledge is power right? It is also known that Power = Work / Time. So then we substitue Power and time so Knowledge = Work / Money. Then we solve for money and get that Money = Work / Knowledge. So, As Knowledge approaches 0, the more money is made regardless of how much work is done.
Now we know that the less you know the more money you make, even with close to no work!
Unread 18-01-2008, 15:21
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Gear Tooth Sensor Question
The gear tooth sensor just reacts to ferous metal passing in front of it. An aluminum washer will not work. The pulse width of the output is 45 microseconds, so if you are looking at it with a meter you likely will not see a change.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-01-2008, 17:46
Semicolon's Avatar
If the washer was pure alluminum, why was it attracted to the sensor? As in the washer is pulled in by the magnetic force of the sensor.
My question is, how can you test the gear toth sensor without a gear?
Unread 18-01-2008, 20:13
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
You'll probably use interrupts to watch your gear sensor, although this introduces another step into your test this would be a good way to test the sensor. Have your RC send an output to an LED (in series with maybe 220 ohms).
Aluminum? If it's attracted to the sensor it's ferrous.
I don't see many aluminum washers unless I specify them.
Unread 18-01-2008, 23:20
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Unless you have some old-fashioned electrical equipment that are designed to sense microscopic electrical pulses, which you might have, you'll have to use the RC and a little programming skill.
You won't be able to detect anything with a basic multimeter, and you won't be able to get much by just hooking it up to a digital-io either. The only way that would yield any output would be if the signal pulse just happened to coincide exactly with the point in the code that reads the state of the digital-io pin. Highly unlikely.
No, as Mr. Neary said, the only real way to utilize the sensor is to program it to a software interrupt, so that the RC actually halts when the sensor sends a pulse and records it. It's not really that hard, it's just that using interrupts involves hardware specific variables that you're probably not familiar with.
If you need any help in that area, ask around the programming forum. Once you set up the interrupt, all you have to do is wave something ferrous in front of the sensor and it'll trigger the interrupt.
Code:
void function(void)
  function();
Unread 19-01-2008, 02:29
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Team Role: Leadership
Rookie Year: 2007
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
The "easiest" way to test the GTS is if you happen to have an oscilliscope handy. Set it up and connect the GTS to the scope, and take a look.
If you don't have a scope handy, software interupts are dead simple in easyCpro.
Set up it to change the OI user display or something.
Unread 19-01-2008, 13:22
void* Jake;
FRC #1178 (DURT)
That's the word I was looking for.
Code:
void function(void)
  function();
Unread 19-01-2008, 22:54
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Rookie Year: 2000
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
[quote=Jake M;681249]
You won't be able to detect anything with a basic multimeter...QUOTE]
Actually you can use a digital voltmeter to read if your gear tooth sensor is working. When all connected and powered up:
Set the DVM to volts DC (VDC).
-connect the black lead to power ground
-check for +5V on the 5/R pad
-check for +12V on the 12/W pad
-check for 0V on the S/W pad (must be close to zero)
-if all checkout OK, then the sensor is likely good and you can go to the next step
Set the DVM to volts AC (VAC)
-connect the red lead to the S/W pad (output signal)
-when you spin a gear within 1mm of the magnetic sensor, you should see an AC voltage rise; it should fall back to zero when you stop moving the gear.
-this works because the sensor board sends out a train of pulses, one for each gear tooth, as the gear is rotated. The DVM interprets them as an AC signal and displays it.
This is a quick-and-dirty way to see if your sensor is working. The best way is to use an oscilloscope.
Set theWhen all connected up, use your DVM to read the voltage on the S (signal output) referenced to ground.
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
