Go to Post Got Valentine's day present from wife before leaving for work. Non-contact IR thermometer, two unscuffed pairs of safety glasses for competitions, bag of York peppermint patties. She understands me. - Greg Young [more]
Unread 17-01-2008, 23:11
baop858 baop858 is offline
FRC #0069 (Hyper)
baop858 will become famous soon enough
Send a message via AIM to baop858
Possiblity of using a few trig functions
Do you guys think there will be an problems if I used like 4 trig function on 28.6 ms loop? If I put the trig functions in the spin function functions would it work better? Would using a look up table for sin cos trig and arctan use up a lot of space?
Unread 17-01-2008, 23:36
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Possiblity of using a few trig functions
This won't be a problem if you aren't doing anything else time consuming.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 17-01-2008, 23:53
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Team Role: Leadership
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
I would say that for most things actual trig functions are overkill, a look up table will good enough. As for space, it depends on how many values you need to calculate, and how many places you need them.
A2D Solving the Imaginary Error Function...
Unread 18-01-2008, 10:23
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Team 95 had done quite a few test bots using field coordinates, where every time through the loop we'd do calls to sin(), cos(), abs(), and atan2(), all while using shaft encoders and the gyro, and it's never been an issue. I wouldn't get carried away, however.
Unread 18-01-2008, 23:55
AKA: Brennan Ashton
FRC #2605 (A2D_16)
I would not expect abs to be take very many processors cycles, could be written as such,
int abs (int num)
if(num<0)
num=(-1)*num;
return(num);
Trig functions in C18 3.10 dmlawrence Programming 9 08-02-2008 09:33
Trig. Functions in EasyC miketwalker FIRST Tech Challenge 5 07-12-2006 23:27
speed of math.h trig functions? Jared Russell Programming 4 07-02-2006 07:13
Trig functions and type conversion kaszeta Programming 6 14-01-2006 23:34
Return of the Inverse Trig Functions Leo M Programming 3 24-01-2002 08:12
